2 hp motor for Laguna MDC0560-0145 cyclone dust collector
Forum topic by mnguy posted 10-26-2018 01:14 AM 630 views 0 times favorited 6 replies Add to Favorites Watch
View mnguy's profile
mnguy
207 posts in 3633 days
10-26-2018 01:14 AM
Topic tags/keywords: motor laguna dust collector 2 hp
This motor has less than 1 hour of run time on it – it is virtually new. Another wood worker in the MINNEAPOLIS area had issues with this unit running that turned out to be starting capacitors, not the motor. In the course of diagnosing the problem, Laguna sent him 2 new motors. I bought the unit from him, and inherited the motors. I have one motor left and will sell it for $100 plus shipping (probably less than $50 for most of you in the US).
View Alex Lane's profile
Alex Lane
542 posts in 4125 days
#1 posted 10-28-2018 12:07 AM
I’m assuming the capacitor problem is fixed? :)
-- Lane Custom Guitars and Basses
mnguy
#2 posted 10-31-2018 04:13 PM
Alex – yes, the capacitor problem was fixed. I actually bought the Laguna DC from another local wood worker, and Laguna shipped him two new motors and a pile of capacitors in the process of trouble shooting the issue. I have extra capacitors, too.
Alex Lane
#3 posted 11-03-2018 11:14 PM
Face mount or base mount? Or both?
View Mike_D_S's profile
Mike_D_S
553 posts in 2449 days
#4 posted 11-04-2018 01:43 PM
Alex,
MNGuy will probably reply, but based on the one used Laguna collector I looked at locally, I believe the motor is face mount only.
Mike
-- No honey, that's not new, I've had that forever......
mnguy
#5 posted 11-05-2018 08:41 PM
Alex,
MikeD S is correct – the Laguna motor is face mount only. I can double check and see if there are threaded bosses or areas that could be drilled and tapped, but I suspect there are none. I can PM you with a couple photos and confirmation.
Chris
mnguy
#6 posted 11-09-2018 01:53 PM
Confirmed – there is no area on the motor housing to tap or otherwise bolt anything to the motor base. To base mount it, you’d have to make a mount that bolted to the face mounting plate.
