This should be on homerefurbers....
Forum topic by JPB posted 08-23-2011 01:13 AM 2438 views 0 times favorited 7 replies Add to Favorites Watch
View JPB's profile
31 posts in 2462 days
08-23-2011 01:13 AM
but this site seems to get a lot more traffic. Forgive me.
I’m looking at putting some 3/4” nail down hardwood over an OSB subfloor. The OSB has quite a bit of tear out from the removal of an old glue down flooring. I’m wondering if anybody has tried leveling compound under a nail down floor. Some have told me the staples will shatter the hardened leveler and some have told me it will be fine. What about Fix-itAll – says its sandable and drillable, anybody know if its nailable?
7 replies so far
View ShaneA's profile
6895 posts in 2531 days
#1 posted 08-23-2011 01:22 AM
What about luan underlayment? Should be a little more than 1/8” thick. Which could create problems with door trim and other things like that. But it will give you a smooth nailable surface.
View JPB's profile
#2 posted 08-23-2011 01:39 AM
I thought about putting something down on top of it, but this problem exists in a hallway with transitions into a dining room and living room. I was afraid the added thickness would make my transitions messy. Luan is only 1/8 of an inch?
View Moron's profile
5032 posts in 3826 days
#3 posted 08-23-2011 01:47 AM
Durobond 90 drywall compound
#4 posted 08-23-2011 02:07 AM
I think it is 5mm, pretty thin, but I figure the hieght increase amost always causes some sort of issue somewhere.
View crank49's profile
4030 posts in 2904 days
#5 posted 08-23-2011 02:57 AM
Unless you have holes more than 12” across I’d just put the hardwood on top of the OSB. 3/4” hardwood won’t sag or do anything weird just because of a little tearout. If the OSB is broken up to the point the hardwood can’t lay flat on top of it, the OSB needs to be replaced anyway.
View JPB's profile
#6 posted 08-23-2011 03:12 AM
Crank – most of the surface has some tear out on it in some form or another. Parts of the glue that was holding down the old floor didn’t hold at all and the square parquet tiles came up with no sweat, but most of it is pretty beat up. My 2 thoughts were 1. replace it or 2. put a skim coat of something on it to fill the tear out – its not very deep.
So you think replace? That makes me sad.
View Sawkerf's profile
1730 posts in 3001 days
#7 posted 08-23-2011 05:30 AM
Figure the cost (time and material) of replacement v.s. the cost (mostly time) of trying to save it. Since it’s OSB, it should be a no brainer.
-- Adversity doesn't build reveals it.
