Bandsaw 9" verses 14"
Forum topic by Blackie_ posted 08-22-2011 11:56 PM 3829 views 0 times favorited 9 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4883 posts in 2753 days
08-22-2011 11:56 PM
Topic tags/keywords: question bandsaw
I have pretty much everything for my shop now, Planer, Joiner, Table saw, drill press, scroll saw, miter saw and Dust Collection so all that I’m lacking now is a band Saw, being that my shop is quite small I was pondering a 9” so that leads me to this question, just how far will a 9” take me apposed to a 14”?
Thanks.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
9 replies so far
View Howie's profile
Howie
2656 posts in 3164 days
#1 posted 08-23-2011 12:20 AM
Depends on what you want to do with it.
Small boxes etc the 9 is okay.
If you want to resaw any the 14” is better.
I have both and the 14 gets used most of the time.
-- Life is good.
View woodklutz's profile
woodklutz
221 posts in 3009 days
#2 posted 08-23-2011 12:44 AM
I have a 10 ” Jet, I would have been wiser to get a 14” More power, better for resawing. But I make do and all works out in the end. If you can swing it go 14. Also blades for 14 are more available.
-- honing my craft one mistake at a time.
Blackie_
#3 posted 08-23-2011 12:46 AM
resaw meaning two boards out of one?
View crank49's profile
crank49
4032 posts in 3212 days
#4 posted 08-23-2011 12:47 AM
From an engineer’s point of view, the 10” band saw is a much better machine than the 9” ones I have seen. Things like metal wheels vs plastic, bigger motor, better guides, cast iron table with fence. I have an older Delta 10” three wheel machine and I would rather have any 9” than it, but I got a Rikon 10” last year and it’s a great little machine. Footprint wise, the difference between 9”, 10” and 14” is insignificant. If I was not planning to build a 16” saw from plans I have already purchased, I would have gone with the HF 14” bandsaw and upgraded it.
Yes, re-saw is splitting a board in thickness. Also used to make veneer.
Blackie_
#5 posted 08-23-2011 01:30 AM
Great information, thanks for the replies,
going to hold off and get a 14” but it’s going to have to be put on the back burner, not sure how long.
View knotscott's profile
knotscott
8183 posts in 3616 days
#6 posted 08-23-2011 02:11 AM
The little plastic 9 inchers can cut wood but are very light, have limited capacity, and vibrate more. 14” is certainly a more capable choice, but you might also look into something like the Rikon clone Craftsman 10” that at least has a cast iron table and heavier frame. I went from a Ryobi 9” to the Cman 12” and it was a night and day improvement.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
#7 posted 08-23-2011 02:16 AM
A 14” bandsaw takes up very little space in terms of its footprint. No more than a benchtop saw on its own small bench. The 14” is more versatile.
View WayneC's profile
WayneC
13809 posts in 4338 days
#8 posted 08-23-2011 02:18 AM
No discussion needed. Go with a 14”.... :)
View Jonathan's profile
Jonathan
2609 posts in 3291 days
#9 posted 08-23-2011 02:46 AM
You’ll certainly be able to do more and varied woodworking projects on the 14”, compared to a 9” or 10”. You can get very skinny blades for the 14” as well that will help you to cut very tight curves. Certainly look into at least upgrading the guide blocks to cool blocks (the more economical route), or the Carter bearing guides. The Carter Stabilizer is also a very nice addition for skinny blades and tight curves. However, the Carter products all add up in a hurry!
I never looked at or considered anything smaller than a 14” bandsaw, for what it’s worth. It depends on what you’re primarily going to use it for though. If you’re going to be doing a lot of small or intricate work on thinner stock, you may want to consider a scroll saw, which will allow you to make cuts inside the outer edges of the wood without having to create a kerf line like you have to with a bandsaw.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
