Which 6" jointer?
Forum topic by shrink posted 08-22-2011 08:18 PM 1320 views 0 times favorited 14 replies Add to Favorites Watch
View shrink's profile
shrink
3 posts in 2836 days
08-22-2011 08:18 PM
I’m just about to pull the trigger on a new 6” jointer. I’ve narrowed the choice to: Grizzly G0452P or a Ridgid JP 0610. Price is a major factor and these machines are basicly in the same ballpark. The Grizzly has a built in mobile base and I’d purchase an HTC mobile base for the Rigdid, bringing them in-line cost wise. I’m not a big fan of the in-feed lever on the Grizzly but also don’t care for the open base of the Ridgid. Small issues but a consideration for me. Any suggestions/advice would be greatly appreciated. Thanks in advance.
14 replies so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3152 days
#1 posted 08-22-2011 08:32 PM
IMO, used 6in jointers can be found all over CL because so many folks upgrade to 8in or larger. If going new I would be looking at at least 8in. I just did a CL search in my area and came up with over 10 today.
Just my 2-cents…
View dbhost's profile
dbhost
5767 posts in 3470 days
#2 posted 08-22-2011 08:38 PM
If you are willing to go used, and have the shop space… I agree with HorizontalMike, try to dig up a used 8” jointer. I am forever needing at least 1” extra over my 6” jointer…
View Tennwood's profile
Tennwood
112 posts in 3419 days
#3 posted 08-22-2011 08:44 PM
I bought the Ridgid about a year ago on sale at HD. I considered the Griz but this was on sale and made up for the 10% sales tax in TN, vs the shipping from Griz. So far it has worked fine. I have used pine, cherry, oak and walnut and it has plenty of power and seems to cut clean. If money were not an issue, I would have moved up to a Powermatic or Jet, or a larger Griz with a helical head. An 8” would be nice, and definitely a longer table, but that isn’t what you are asking. The only issue I have had is that over time the fence will slowly move out of square with the table. Just something I have to monitor. I would say about 90%+ of the chips go into the DC without any clogging. I ended up putting casters on the legs, which makes it a little wobbly, but works. I don’t think you will go wrong with either.
Good luck.
-- Jim, SE Tennessee, "Don't spare the kindling Dear, we have plenty"
View Bertha's profile
Bertha
13551 posts in 2931 days
#4 posted 08-22-2011 08:49 PM
Used all the way. That $500 you’re going to spend at Lowe’s will go a long way on the used market. If you’re dead set on new, I’d pick the Rigid out of those two. What about a Steel City? I think the big box stores have them now.
117417 posts in 3815 days
#5 posted 08-22-2011 08:58 PM
I think you can get a used 8” in that price range but if it were me I would save up and get a spiral head unit, they have many advantages. I have had good luck with grizzly and I think their unit is heavier than the Rigid.
http://www.grizzly.com/products/6-X-46-Jointer-w-Spiral-Cutterhead/G0452Z
View Gerry's profile
Gerry
264 posts in 3479 days
#6 posted 08-22-2011 09:05 PM
I have the Ridgid, and it’s been fine for my purposes. That said, I must agree with the others here, as cost is a major issue for you, that used is the way to go. I have had the same experience as DBHost re the limitations of the 6” jointer, but cannot justify the additional expense. CL is where I found mine, along with a Dewalt 735 Planer. Best of luck in making your choice!
Gerry
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
View TheDane's profile
TheDane
5575 posts in 3901 days
#7 posted 08-22-2011 09:09 PM
I have a G0452 … bought it two years ago, and have never had a second thought.
It was easy to setup, but it was apparently shipped with a nicked knife. Grizzly customer support immediately shipped me another set of knives, and I have been a happy camper ever since.
—Gerry
View thebigvise's profile
thebigvise
191 posts in 3138 days
#8 posted 08-22-2011 09:17 PM
I agree with a1Jim. Although you said that price matters—very understandable—I would do all that I could to get a helical cutterhead. The price might sting some initially, but you’ll never look back. You’ll likely have a lifetime of pleasure using a machine which is a meaningful advance over the old 3-knife system. I recommend the 6” Powermatic with helical cutterhead; uses 110 volts and has plenty of power.
-- Paul, Clinton, NC
View GregD's profile
GregD
788 posts in 3374 days
#9 posted 08-22-2011 09:23 PM
I have a 6” Craftsman Professional series jointer with a lever control for the infeed table. It works just fine for me. As long as the infeed bed slides smoothly I see no disadvantage to the lever.
My jointer has a similar footprint to the Grizzly. I have to add support to the outfeed table if I’m jointing long (80”) stock. The Rigid looks to have an advantage there.
I am not so pleased with the fence mount on my jointer. I have it set at 90 degrees and it seems to do a fine job of keeping it there. But I have little confidence that it is easy to change the angle for a bevel and then return the fence reliably to 90 degrees. From what I could see from the pictures it is not clear that the Grizzly fence mount is better. I didn’t see anything on the Rigid. I have looked at the Delta 37-275X X5 jointer and it’s fence mount inspired more confidence, but I didn’t play with it much. I don’t think it is unique to Delta, but it may require a step up in price. Not clear to me whether this feature is worth the price.
The other thing to consider is a spiral cutter head, if you are buying new.
For basic work I don’t see much downside to Mike’s suggestion on buying a used jointer in good condition. Check that the fence and beds are flat, that the beds move smoothly and remain co-planar.
-- Greg D.
View vernonator's profile
vernonator
75 posts in 2889 days
#10 posted 08-22-2011 09:41 PM
I just got the Grizzly G0452P – only run a few boards thru it but (except for my technique) it planes smooth as butter. Its very quiet and with dust collection hooked up leaves virtually no shavings behind. I am happy…and no I did not get the helical head, could not justify the extra $300 for a hobbiest tool. I know everyone says “get an 8” you will regret it” Well if they want to come and install a new panel in my house so I can get a 220 line in the shop AND haul an 8” machine down the stairs into the basement for me then I guess I should have gotten an 8” one :) I used a 5% coupon and got it for $496 delivered, thats cheaper than the Rigid delivered from HD (looked at that one too) AND the mobile base is built in.
View Grandpa's profile
Grandpa
3261 posts in 2913 days
#11 posted 08-22-2011 09:46 PM
Loren advertised an 8 inch Powermatic last week (Green paint on it) for ….make an offer
View dpop24's profile
dpop24
115 posts in 2807 days
#12 posted 08-22-2011 09:47 PM
If you are set on new, don’t forget to take your 20% Harbor Freight with you to Home Depot as they will honor it on a single item tool purchase. For me that makes the decision of getting a new Ridgid with a warranty a bit more compelling than saving a bit of money on the used market.
I went used on my jointer purchase but other tools are right in the ballpark cost-wise after the discount – for around the same as people are asking for their used machines. Seems most people want to sell for the same price as you can buy a new one because they’ve “only used it a few times”.
-- If it ain't broke, take it apart and find out why
View ferstler's profile
ferstler
342 posts in 3758 days
#13 posted 08-22-2011 11:43 PM
Both probably work just fine. I have the Ridgid and reviewed it at:
http://lumberjocks.com/reviews/466
Sure an 8 incher will do more. However, some users might not have the space, and in my review I noted how I mounted mine on a roll-around stand. I guess you could also do that with an 8 incher, but in any case I have a small shop and the roll-around feature is important.
Howard Ferstler
View doninvegas's profile
doninvegas
334 posts in 3145 days
#14 posted 08-23-2011 12:58 AM
I have the G0452 as well. It’s a great machine but, my shop floor isn’t smooth and I knocked off the leveling legs. Griz customer service told me I would have to find a local welder to weld the internal nuts back on. I ordered a set of replacement knives when I bought the thing but when it was time to replace them they were the wrong ones. Griz sent me a new set and we split the difference in price. All in all it’s a good tool. The only reason I got the 6” instead of the 8 is because of the table length. My shop is WAY TOO SMALL.
-- "Courage is being scared to death -- but saddling up anyway."
