best filler for knots in black walnut?
Forum topic by romeege posted 10-23-2018 07:48 PM 980 views 0 times favorited 22 replies Add to Favorites Watch
View romeege's profile
romeege
21 posts in 3250 days
10-23-2018 07:48 PM
Topic tags/keywords: knot filler
I am wondering how to deal with these two big holes in two knots….here are a couple pics… thanks for any ideas guys!
22 replies so far
View HokieKen's profile (online now)
HokieKen
7655 posts in 1380 days
#1 posted 10-23-2018 07:56 PM
I’ve dealt with similar knots 2 ways. One is to mix Walnut sawdust with yellow wood glue and use it like putty to fill it. The second, and my preference for your situation, is to mix some black dye in epoxy and use that to fill.
-- Kenny, SW VA, Go Hokies!!!
View Andre's profile
Andre
2375 posts in 2048 days
#2 posted 10-23-2018 07:58 PM
Epoxy and or with a little charcoal?
View Manitario's profile
Manitario
2705 posts in 3125 days
#3 posted 10-23-2018 08:00 PM
Depends what sort of look you want. I’ve used epoxy many times to fill knots; eg. West Systems. You can leave it clear, tint it etc.
View ScottM's profile
ScottM
703 posts in 2388 days
#4 posted 10-23-2018 08:05 PM
Just plain epoxy. No sawdust or fillers.
View Zonker's profile
Zonker
27 posts in 93 days
#5 posted 10-23-2018 08:05 PM
I have used Fiberglass resin in SYP with good results. It is very watery so you’d want to tape the back side so it all doesn’t just run out. It dries fairly clear and pretty hard, will sand nicely, but it won’t take stain. I’ve never tried adding any dyes to it, but I googled that and it seems possible. Hope this helps.
-- Larry A. - I've made a small fortune with my woodworking. The trouble is, I started with a large fortune.
View waho6o9's profile (online now)
waho6o9
8539 posts in 2819 days
#6 posted 10-23-2018 08:10 PM
Maybe knock it out and glue in a walnut dowel.
View Woodchuckswife's profile
Woodchuckswife
26 posts in 1552 days
#7 posted 10-23-2018 08:20 PM
Walnut saw dust and glue mixed like a paste fill and let dry, then sand with a lite coat of glue and let dry. then finish sand. I have don cracks that way and then later could not find them even knowing they were there.Good luck.
Chuck
romeege
#8 posted 10-23-2018 08:32 PM
thanks guys…it looks like epoxy is the winner, but I guess the trick will be how to squeegie it off of surface flush… the piece is already finished
View Snowbeast's profile
Snowbeast
97 posts in 1580 days
#9 posted 10-23-2018 08:47 PM
I usually pack it full of walnut sanding dust and then drizzle with thin CA glue. Actually, a slight overfill works best. Then just sand flush.
Can’t help you much with the already finished part. But next time…..
View GaryCN's profile
GaryCN
371 posts in 4176 days
#10 posted 10-23-2018 09:02 PM
I’ve done that, fast fix as you can sand it in almost immediately.
Can t help you much with the already finished part. But next time…..
- Snowbeast
-- Quando Omni Flunkus Moritati
View Aj2's profile
Aj2
1954 posts in 2040 days
#11 posted 10-23-2018 10:19 PM
That is not a bad looking knot. Not every knot needs filling so I would not worry about it.
See what I did :<)
-- Aj
View pottz's profile
pottz
3858 posts in 1226 days
#12 posted 10-23-2018 10:29 PM
I ve dealt with similar knots 2 ways. One is to mix Walnut sawdust with yellow wood glue and use it like putty to fill it. The second, and my preference for your situation, is to mix some black dye in epoxy and use that to fill.
- HokieKen
ditto but already finished is tough.you could try and fill as close as you can then take a razor blade and cut it flush before the epoxy gets totally hard,but i dont know how good its gonna look.maybe just live with it.
View LesB's profile
LesB
1924 posts in 3685 days
#13 posted 10-23-2018 10:34 PM
I’m a fan of the CA glue technique. Much easier to use than epoxy. There are three thicknesses of CA glue. I find medium works for most cracks, knots (still in place), and voids. For larger openings I fill then with fine sawdust then apply a shot of thin super glue followed immediately with the thick glue. The thin glue acts as a wicking agent to draw the thick glue into the sawdust. Keep adding the thick glue until it stops soaking in. It can take 15 minutes or so for the glue to set up in a deep opening or use the accelerator spray.
I collected the sawdust from a orbital or belt sander with a dust collector bag attached. I have a collection of various sawdust wood types saved in small jars and use this technique all the time on lathe work.
-- Les B, Oregon
View bilyo's profile
bilyo
478 posts in 1344 days
#14 posted 10-23-2018 10:46 PM
- romeege
Since you all ready have finish on it, your options are more limited. Aj2 suggested leaving it alone which is a good suggestion if your taste will tolerate it. Otherwise, if you are very careful, you might be able to fill with epoxy just til it reaches the rim of each hole. Let surface tension mound it up a bit, but don’t let it run out onto the adjoining surface. Once cured you might then be able to carefully shave, scrape, and/or sand level without much damage to the finish. You will need lots of care and a bit of luck.
The thought occurs to me that you might be able to apply a coat of wax around the area before applying the epoxy. Just don’t get any in the holes, of course. Another idea: if the knot holes go all the way through, maybe you can apply some wide clear packing tape over the holes on the finished side and then apply the epoxy from the back and let it cure. Once cured, the epoxy surface should be close to flush and require very little work, if any. It might not be perfect, but maybe close enough, as they say.
View Rich's profile
Rich
4013 posts in 831 days
#15 posted 10-23-2018 11:02 PM
Even if you can level the epoxy, you will still need to give it another topcoat, otherwise the sheens won’t match.
Unless the area will see significant wear, I’d go with ebony colored Timbermate. It’ll be the easiest to level using a putty knife, and a quick touch up with 320 or 400 grit paper will smooth it completely. Then give it one more coat of finish to seal it.
