Help! I need CNC help with a sign for upcoming trade show
Forum topic by Kiersten posted 08-22-2011 05:17 PM 1687 views 0 times favorited 6 replies Add to Favorites Watch
View Kiersten's profile
Kiersten
69 posts in 3678 days
08-22-2011 05:17 PM
Topic tags/keywords: cnc router wood
Hi everyone!
I need some advice from you CNC folks! I’ve been trying to get ahold of a CNC shop (in LA area) I used before partnering with an Amish furniture manufacturer and I’m not having any luck. I’m in desperate need of some CNC help. I’m attaching what I need done and am interested in knowing if any of you would like to to crank it out on your CNC, if possible. If you’re in or near LA, that’s even easier!
Please see the attached photos. One is of the sign (letters) and the other is an overall view of the booth. I’ll be mounting the letters to the back walls using small blocks.
Basically, I was thinking of having them cut out of mdf or whatever is cheapest. As for the letters, basically stacking 4 3/4 inch mdf cut-outs on top of each other. I’ll glue them up to give lots of dimension. I’ll do all the glueing and painting, I just need someone to do the cutting. I have a vector file of my logo.
Please let me know if you’re interested or if you know a CNC shop or a Lumberjock with CNC router here in LA area. You can comment here or send me an email to kiersten@modmomfurniture.com.
Thanks so much!
Kiersten!
https://s3.amazonaws.com/vs-lumberjocks.com/lqc4z4j.jpg!
https://s3.amazonaws.com/vs-lumberjocks.com/lqc515b.jpg!
-- Kiersten, Los Angeles, http://www.modmomfurniture.com
View ChrisK's profile
ChrisK
1973 posts in 3108 days
#1 posted 08-22-2011 05:36 PM
Kiersten,
Sorry I cannot help with a CNC shop, but you might want to look at using sign foam and having it water jet or cut at a sign shop. The following link is one brand http://www.signfoam.com/product.php?mode=sf3. You can get the material up to 12” thick and it is a whole lot lighter than MDF. The cost of the material might be higher but with a payoff on only having to cut o part instead of multiple to get the thickness. The finishing is about the same.
Chris
-- Chris K
Kiersten
#2 posted 08-22-2011 05:42 PM
Chris, thank you!! What a great idea!! I’m new to anything having to do with signs so that makes a lot of sense!!
View TimL's profile
TimL
36 posts in 2800 days
#3 posted 08-22-2011 05:45 PM
Kiersten,
I have a CNC and can produce what you are asking for. I will message you with details.
Tim
View TheWoodsman's profile
TheWoodsman
65 posts in 2922 days
#4 posted 08-22-2011 06:30 PM
Is this for your Louisville show?
I’m about two hours from there and half hour from Cincy. I have access to Biesse and Northwood cnc equipment and could help with painting and assembly if needed.
James
-- I'm the Woodsman . . . the four-wheelin', tree-farmin', custom-furniture-makin' descendant of Olaf "The Woodcutter" Ingjaldsson.
Kiersten
#5 posted 08-22-2011 07:34 PM
Hey James! It is for the ABC Kids Expo in Louisville. :) I am in talks with Tim (above) but if I need a second option, can I call you? I’ll know this week. Thanks!!
TheWoodsman
#6 posted 08-22-2011 08:23 PM
I will send you an email with my contact info.
