CA stains
« back to Woodturning forum
Forum topic by Karda posted 10-23-2018 12:24 AM 586 views 0 times favorited 13 replies Add to Favorites Watch
View Karda's profile
Karda
1379 posts in 787 days
10-23-2018 12:24 AM
when using CA to fill cracks on bowl blanks some gets on the wood surrounding the crack especially if the are small and sometimes it don’t sand out. can anything be done with it
13 replies so far
View LeeMills's profile
LeeMills
629 posts in 1535 days
#1 posted 10-23-2018 12:46 AM
I dip a finger tip in shellac and give it a light coat. It seals the wood from the CA. May take a minute or two for the shellac to dry.
Karda
#2 posted 10-23-2018 03:53 AM
ok but won’t that keep the CA out of the crack as well
View TheDane's profile (online now)
TheDane
5573 posts in 3896 days
#3 posted 10-23-2018 01:14 PM
Not necessarily … note his emphasis on light coat.
View Rich's profile
Rich
3978 posts in 823 days
#4 posted 10-23-2018 03:14 PM
You can try a more viscous glue. A medium thickness will help reduce the spread and penetration into the grain. If that’s too thick, Starbond makes one they refer to as heavy thin, which is kind of in between medium and thin.
I tried all sorts of sealers and found that they were as much of a problem to remove as the glue itself. Going a bit thicker helped.
Karda
#5 posted 10-23-2018 03:43 PM
ok thanks i’ll try that
View Woodknack's profile
Woodknack
12455 posts in 2614 days
#6 posted 10-23-2018 04:17 PM
Don’t wait so long to fill the defect. Fill it when still in the tool phase, before you start sanding.
Karda
#7 posted 10-23-2018 05:45 PM
when do that I just open the crack back up, I have even sanded some smaller crack open that had to be re glued
Woodknack
#8 posted 10-23-2018 06:01 PM
I suspect you are only getting the filler on the surface and then cutting it away. I add filler, ca, more filler, ca, filler, ca; until the defect is full. Then take my final light cuts.
Karda
#9 posted 10-23-2018 08:45 PM
these are small cracks to small to use a filler of any kind
LeeMills
#10 posted 10-23-2018 09:35 PM
Applying by fingertip I can tell how much is applied better than by a small brush. It could fill a small (sheet of paper thickness) crack I guess but not nearly enough to fill a crack the thickness of a credit card. I do use my shellac wash coat so it has been thinned with 2 parts DNA. Just enough to seal the surface to keep the CA from staining the wood. You can probably use any sanding sealer.
Sorry about my delay in posting.
To add, if you are having the cracks re-appear you may need to go to a thin CA. It may takes several application to fill the crack but the thin CA should penetrate even the smallest crevice.
Karda
#11 posted 10-24-2018 04:02 AM
ok thank
View Wildwood's profile
Wildwood
2521 posts in 2368 days
#12 posted 10-24-2018 03:39 PM
Lot of ways a woodturner can deal with shallow or deep cracks in surface of the turning. While CA glue is great for sealing cracks you have to turn or sand away any excess while still on the lathe.
Filling cracks made a lot easier if use combination of fill & CA glue. Choice all about matching wood color or using contrasting colors. Fill can be anything from saw dust, new or used goffee grounds, green or herbal teas.
Old metal shavings, minerals or stone often used for contrasting colors.
I use an electric coffee grinder to grind further any fill will use. In-expensive under $20 or used grinder will work well whether electric or hand crank models. Have never used metal, mineral, or stone for fill.
Fill the crack flush before applying CA for shallow cracks. May take couple applications of fill & CA glue for deep cracks.
Only real secret is take your time!
-- Bill
Woodknack
#13 posted 10-24-2018 04:10 PM
- Karda
If they are that small, which would be pretty small, I wouldn’t worry about them.
