Will a Shelix head plane UHMW or HDPE?
Forum topic by Gene Howe posted 10-22-2018 03:53 PM 672 views 0 times favorited 15 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
11168 posts in 3670 days
10-22-2018 03:53 PM
Topic tags/keywords: s helix plastics planer
The title is my question for the guys who have tried it. Need to shave off a few thousandths.
15 replies so far
View mramseyISU's profile
mramseyISU
570 posts in 1787 days
#1 posted 10-22-2018 04:05 PM
I’ve machined it in a mill and it doesn’t machine well at all. It would melt against my end mill and leave a terrible surface.
-- Trust me I'm an engineer.
View Andre's profile
Andre
2375 posts in 2048 days
#2 posted 10-22-2018 04:11 PM
I flatten the bottoms of Plastic snow shoves every winter, use a 12” scorpion carbide, only 1/8” to 1/4” width but good clean finish.
5244 posts in 2735 days
#3 posted 10-22-2018 04:15 PM
I haven’t planed with a Shelix, but I have jointed some (with a Shelix) , and it worked fine. In the past I’ve planed it with knives before I converted the planer and that too worked fine. It is a mess, the clippings stick to everything.
View TheFridge's profile
TheFridge
10818 posts in 1728 days
#4 posted 10-22-2018 04:26 PM
I have. It works ok/well.
Gene Howe
#5 posted 10-22-2018 04:30 PM
Thanks for the replies and info.
I tried a plastic cutting board from Walmart with the DW735 and the straight blades. It shattered. Of course, I really don’t know the composition of that board.
View Jim Jakosh's profile
Jim Jakosh
21977 posts in 3347 days
#6 posted 10-22-2018 04:39 PM
Hi Gene..A few thousandths? can you use a scraper..like a card scraper or a fine mill file? I have a plastic cutting file and run it sideways to do fine scraping on plastic. I think any cutter head would take off way too much.
cheers, Jim
View robscastle's profile
robscastle
5633 posts in 2446 days
#7 posted 10-22-2018 07:00 PM
Hello Gene,
I have planed some.
Mind you it was more than a few thou but should work just the same, have a look.
More importantly there are some valuable replies adding additional information if your working with it
http://lumberjocks.com/robscastle/blog/102666
-- Regards Rob
TheFridge
#8 posted 10-22-2018 07:35 PM
I had uhmw for a table saw fence. And a shelix head
View mnguy's profile
mnguy
210 posts in 3640 days
#9 posted 10-22-2018 08:02 PM
Cutting boards are almost always polypropylene, which will be generally be more brittle than HDPE or UHMWPE. As you approach 32 F temp, polypropylene (PP) gets very brittle indeed.
I have found that PP cuts well on the table saw (I like it for zero clearance inserts), but have never tried to join or plane any plastic materials.
Gene Howe
#10 posted 10-22-2018 09:09 PM
Jim, maybe I needed to be clearer. I meant I was trying to JUST take it down a few thousandths at a time. Trying to avoid what happened.
My goal is to make ZCIs for my saws.
Mnman, you’re probably correct about it being PP. It does cut well. But it seems to be more brittle than known UHMW pieces that are parts of jigs.
Next project is surfacing a mequite slab with a router surfacing jig. When I’m done, I’ll try it on the cutting board.
View MrUnix's profile
MrUnix
7117 posts in 2441 days
#11 posted 10-22-2018 10:42 PM
I’ve run HDPE through the planer without any problems – but on a straight knife planer, not a helix head one. The helix head would probably be better, as it will produce small chips rather than the long strings I got… those long pieces wanted to clog up the works if you let them get out of control. Here is some homemade ‘bag lumber’ (made from grocery store bags melted down in the oven) showing the long strings produced:
Gene Howe
#12 posted 10-23-2018 12:37 PM
Hey thanks, Brad. Can you tell me more about processing and use of “Bag Lumber”? Think it’s stiff enough for a ZCI?
MrUnix
#13 posted 10-23-2018 10:13 PM
Hey thanks, Brad. Can you tell me more about processing and use of “Bag Lumber”? Think it s stiff enough for a ZCI?
- Gene Howe
I already spoke with Gene via PM, but for anyone else interested – the ‘bag lumber’ above was made using grocery store bags melted in the oven at 350F, and eventually ‘pressed’ between two pieces of wood to create an even thickness and keep it flat as it cooled. As long as you don’t make it too thin, it would make an excellent insert for the table saw IMO… although I have never tried it. I do however make inserts out of HDPE for the band saw and scroll saw which work great (but made with a different technique).
View DrDirt's profile
DrDirt
4526 posts in 3984 days
#14 posted 10-24-2018 04:36 AM
No – some point out the carbide cutters aren’t really that sharp, so it wants to chew the plastic…
However my “no” is because you only want to shave a few thousanths. I find you need a deep enough cut on my planer, because the steel tooth feed roller leaves marks, that you need to be taking more than 1/64th off, to remove the machines tracks/marks
As I recall the DW735 has a rubber infeed, so should not be an issue, but I have a 15inch PM with the helical head, and the roller leaves ‘tooth marks’ if the cut is too light. (needs more than ~1/8th turn)
View shipwright's profile
shipwright
8189 posts in 3040 days
#15 posted 10-24-2018 03:57 PM
Gene, in another topic you mentioned that you have a few of the drill press planing gadgets. Would they not be the cat’s bum for this?
