Thru Tenon Domino Drawers
« back to Joinery forum
Forum topic by rwe2156 posted 10-22-2018 02:09 PM 531 views 0 times favorited 9 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
3234 posts in 1721 days
10-22-2018 02:09 PM
I’m sure this isn’t something new, but I’ve never seen it anywhere so I thought I would post.
After using the Domino a bit, it occured to me it could be used for through tenons and since I had some drawers to build here’s what I came up with. This was a “think as you go” type thing so feel free to make suggestions.
First thing was make a jig to hold the sides and front/backs in alignment:
The side is clamped vertically and the front/back held in place with a holdfast.
The cut is made. I set the depth so about 1/8” of tenon was exposed.
Finished result. I cut the exposed tenons off with a reciprocal saw. With a little practice I could get it close enough that just a little sanding is all that is needed to make them flush.
Once I got the process down & got rolling, I made and assembled 6 drawers in less then 1 hour. I know I can reduce this time considerably with practice.
One big mistake I made was not paying close attention to whats the inside of the front and backs. The tape on the sides made that obvious. But it won’t be crucial as the tenons are all set the same distance.
The other mistake was not accounting for the groove, which I corrected about 1/2 way thru. The top tenon is 20mm from the edge and the bottom is 20mm from the top of the groove, then center of those for the 3rd. In the future, I’ll gang up & mark the drawer bottoms and middle tenons which basically makes all the parts interchangeable.
I clamped them but honestly I don’t know they really needed clamping. Next time I’ll probably make some clamping cauls with tenon holes to account for the protruding tenons.
I wouldn’t use this on fine furniture, but I think it would be useful for cabinetry.
Let me know what you all think!
9 replies so far
View Redoak49's profile
Redoak49
3744 posts in 2229 days
#1 posted 10-22-2018 02:22 PM
Interesting way to make drawers….
View waho6o9's profile (online now)
waho6o9
8539 posts in 2817 days
#2 posted 10-22-2018 02:33 PM
I like it, good job.
View EarlS's profile
EarlS
2128 posts in 2588 days
#3 posted 10-22-2018 02:34 PM
Those look pretty fine to me.
I’ve done some through tenons on sides and legs using the Leigh M&T jig (which produces the same rounded edge profile) and they look every bit as nice as a square through tenon. I think the exposed cross section and protrusion of the tenon is what draws the eye more than square vs. rounded corners.
View GR8HUNTER's profile (online now)
GR8HUNTER
5398 posts in 952 days
#4 posted 10-22-2018 03:22 PM
SIMPLY GREAT IDEA :<))
View AlaskaGuy's profile
AlaskaGuy
5000 posts in 2549 days
#5 posted 10-22-2018 05:21 PM
Your suspicions are correct. Domino drawers have been around quite a while. I’ve done it myself.
https://www.google.com/search?q=domino+drawer&client=firefox-b-1&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwi5-q-Kx5reAhVVE4gKHbHZA4cQsAR6BAgFEAE&biw=1408&bih=652
View oldnovice's profile
oldnovice
7380 posts in 3608 days
#6 posted 10-22-2018 05:43 PM
I really like the looks of the domino assembly!
Different and at the same time looking very sturdy.
I have used bisquits for drawer assembly but the bisquits are not visible and it is a lot of extra work.
View Kazooman's profile
Kazooman
1268 posts in 2192 days
#7 posted 10-22-2018 08:29 PM
A flush cutting trim saw will make short work of cutting off the dominos leaving very little sanding.
https://www.woodcraft.com/products/veritas-flush-cutting-saw-double-edge-22-tpi
View pottz's profile
pottz
3840 posts in 1224 days
#8 posted 10-22-2018 10:14 PM
never thought about doing this but i will consider it for future projects,i like the look.thanks for posting this.
runswithscissors
2928 posts in 2265 days
#9 posted 10-22-2018 11:33 PM
My preference for cutting the tenons flush would be an oscillating multi tool. If you were to grind the bottom of the blade smooth (eliminate tooth set from the bottom), there would be few if any scratches on the drawer sides. I like the so-called Japanese style blades, as they cut quickly yet smoothly. Otherwise, it looks like a good way to make drawers.
I’m just waiting for HF to come out with a clone of the Domino for $79.95 (minus a 20 or 25% coupon, of course).
