Work bench
Forum topic by SweatyTeddy posted 10-22-2018 01:43 AM 1058 views 0 times favorited 26 replies Add to Favorites Watch
View SweatyTeddy's profile
SweatyTeddy
50 posts in 1020 days
10-22-2018 01:43 AM
Build or buy a work bench? It seems like a huge project and I would love to to do it but I can’t figure out a design that I like. I have seen some for sale that I like but I don’t want to spend the money on it. Would it be more pocket friendly to build or buy one?
-- I'd be done by now if I knew what I was doing! - said by no man ever with a woman present
26 replies so far
View TravisH's profile
TravisH
641 posts in 2170 days
#1 posted 10-22-2018 02:29 AM
Pocket friendly all depends on you. Some spend a lot on building a bench but you can easily build a better quality bench cheaper than what you are going to get for similar money new.
I used 4×4 and 2×4 for the base (reused from my daughters loft bed). Then 2 oak butcher block tops screwed together. I used a 20 dollar press screw to make my tail vise and then a 35 dollar shoulder vise screw. Then plywood drawers beneath.
Not the prettiest but wasn’t intended to be.
View Aj2's profile
Aj2
1947 posts in 2033 days
#2 posted 10-22-2018 03:11 AM
I bought my top and built the base.
All hard maple
-- Aj
Rick Dennington
6346 posts in 3430 days
#3 posted 10-22-2018 03:30 AM
For me it was a no brainer…..I would have liked to have had a high $$ bench made of Beech or Maple, but I decided to build my own…In fact I’ve built 4 benches…..The frames were made of Douglas fir, and different types of woods for the tops….My main work bench is made of Douglas fir, has a 4” laminated top, is 101” long, 42” wide and is 42” high…..I like my benches high, as I have a very bad back, and I don’t like leaning over more than I have to…..You’ll get more pleasure out of building your own, learn from the experience, and you can say “I built this bench”.......My main bench I built about 12 years ago, and use it almost daily….Besides the table saw, the work bench is the main attraction of your shop…..!! I also built the cabinet under the bench with plenty of drawers and storage…..!! Two vices, and 2 power strips….one on each end…..!!
-- " At my age, happy hour is a crap and a nap".....!!
View CWWoodworking's profile
CWWoodworking
184 posts in 414 days
#4 posted 10-22-2018 04:12 AM
If you are in this to be a perfectionist, build it. If you are in it to make money, make/buy a system to work for you. I used Menards plastic corners with 2×4’s and plywood. I will produce A LOT of product this year. I not about precision, more about production.
View BlasterStumps's profile
BlasterStumps
1063 posts in 675 days
#5 posted 10-22-2018 01:14 PM
Take a look at the bench in this publication. It is not all that difficult to build. Splayed legs make it quite stable.
http://toolemera.com/bkpdf/haywardhowtobk.pdf
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View JayT's profile
JayT
6007 posts in 2446 days
#6 posted 10-22-2018 01:31 PM
If you are doing woodworking as a hobby, build it. There are many reasons I say that.
  • It gives you a chance to practice a variety of woodworking skills on something that doesn’t have to be furniture grade.
  • It’s far less expensive. You can build a far more solid bench than you can buy, unless you spend quite a bit. Use whatever lumber you have available that is cheap, stable and relatively dry. My first real woodworking bench was built for less than $200, including vises, from construction lumber, some of which was reclaimed, and has served well.
  • You can build in features that fit how you work instead of adjusting your way of working fit the bench. There’s a big difference in how a bench should look for power tool focus versus hand tools. Make the best choices you can right now. Which leads us to . . .
  • If you are like most people, the first bench is just that, a first one. You state you don’t know what design you like. That’s OK, just build a bench that fits how you think you need it to function. As you use it and figure out what you do and don’t like about that bench, you’ll start to develop an idea of what your ideal bench would look and function like. Then you will be ready for a nicer one. I’m in the process of building my second bench. It will be taller, narrower and a bit shorter in length than the first one and have different work holding. Most importantly, it will far better fit how I work.
-- In theory, there is no difference between theory and practice. In practice, there is.
View Tony1212's profile
Tony1212
266 posts in 1970 days
#7 posted 10-22-2018 01:37 PM
Extenuating circumstances aside, it’s easier on the pocket book to build your own. Most people have more time than money, so I usually choose to invest my time in something like this.
I could have built a Thein dust separator, but I had other pressing issues that took precedence. So I bought a cyclone dust collector instead. That’s one instance I chose to invest money rather than time.
BTW, extenuating circumstances might be something like you’re doing this as a business, so you’re actually losing money by spending time on your bench rather than client work, but that’s an ROI you’d have to determine yourself.
-- Tony, SW Chicago Suburbs
View MrRon's profile
MrRon
5261 posts in 3479 days
#8 posted 10-22-2018 04:37 PM
It would seem to me that a hobby woodworker builds things from wood. If he buys it, then it’s not woodworking. I am and always have been about building everything that I can rather than buying something that is buildable without the need for specialized tools or machines. DIY to me means doing as much as possible yourself.
Some say they don’t have enough time to build a bench or jig. If that is the case, then they probably don’t have enough time to do woodworking at all. They should look for another activity.
View Mr_Pink's profile
Mr_Pink
136 posts in 607 days
#9 posted 10-22-2018 09:34 PM
Like Travis, my bench is a mix. The top is two layers of hardwood butcher block glue and screwed together. (In my case, the best deal involved buying a 2’x12’ countertop from a local cabinet shop and cutting it in half.) The base is made of 4×4s, following Schwarz’s “two-day workbench”.
View bigJohninvegas's profile
bigJohninvegas
542 posts in 1697 days
#10 posted 10-22-2018 11:56 PM
build your own, pocket friendly for sure. Big question is what are your needs? Take the time to figure this out.
Are you a hand tool woodworker? Or mostly power tools.
I really like the Rubio style benches. Lie Nielsen benches are very nice, but the cost does not work for me.
So after a year of planing to build my own from Fir. I realized that a Rubio style bench simply was not going to work for me. We all have different needs. For me, my bench had to be a work bench, assembly table and outfeed table for my table saw.
So in the end, I loosely copied a bench that I liked using at a woodworking school here in my home town.
Two 5’X5’ sheets of 3/4” baltic birch ply for the top. A 4’X8’ sheet 1’ ply for apron and stretchers. and I had a bunch of poplar from a project that I never got around to building that I used for the legs. So with my vise, I am into it for about $300. And it is a rock.
Take your time to figure out what works for you.
-- John
View jonah's profile
jonah
1971 posts in 3534 days
#11 posted 10-23-2018 01:17 AM
There’s nothing wrong with buying a workbench, but there’s also a lot of good arguments for building your own. For one thing, it’s good practice. For another, you get exactly the size and features you want. The third factor is price: building your own will cost a lot less.
I built my bench, and I’m glad I did. It’s not a “forever” bench, and I can see replacing it someday when I have the time and money to build something out of maple or beech, but for now, it does the job superbly.
View TheFridge's profile
TheFridge
10814 posts in 1721 days
#12 posted 10-23-2018 01:24 AM
I used 100+ offcuts from a local cabinet shop for a 48”x20” top. Labor of love doesn’t cover it but I would do it again if I had the chance. Learned a lot from that build. I had to buy a gallon of glue and the acme screw and nuts for the vise.
View Eric's profile
Eric
79 posts in 108 days
#13 posted 10-23-2018 01:28 AM
I would build it over buying. Worth the money spent and time to build one. And yes build it to meet your needed and style. And with building it, you can make it sturdy using construction materials.
Good luck
-- Eric, Upstate South Carolina
View BattleRidge's profile
BattleRidge
86 posts in 451 days
#14 posted 10-23-2018 02:36 AM
I had specific wants and needs for my combination workbench, assembly table, outfeed area and thus built it myself. Also, given the size (4’ x 8’ x table saw height) and the construction (2” x 6” framing with a top of two 3/4” layers of plywood with a hardboard work surface), I designed it to be stationary and a solid work area (it doesn’t budge while in use). I’d hate to see the shipping charges to transport it.
Mine is still a work in progress with more additions to come as the funding allows – a vice or two, drawers, etc.
I had considered a variety of other designs but have been more than happy with what I have. My work area is assembled with screws to allow for modification or disassembly if ever needed, but since putting it to use, I see no reason to ever do so. I did use a brad nailer to fasten the oak trim around the edges to keep the hardboard top in place (the hardboard is also affixed with double sided tape to allow for future replacement should it become damaged or worn).
View CL810's profile
CL810
3886 posts in 3223 days
#15 posted 10-23-2018 03:08 AM
+10 to Jayt’s comments. Looking for a bench style? Read this thread.
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
