Dove tails
Forum topic by SweatyTeddy posted 10-22-2018 01:23 AM 321 views 0 times favorited 5 replies Add to Favorites Watch
View SweatyTeddy's profile
SweatyTeddy
50 posts in 1019 days
10-22-2018 01:23 AM
I finally have time to get back into my shop. I’ve done some easy stuff to get my groove back on. But tonight I just took a wack at doing dove tail joints….. And I SUCK. I know it’s an art form I grew up watch the woodwrite shop and I remember him making it look so easy. I was surprised at how much I remembered about how he did it. I know there are router bits and jigs and whatnots, but I kinda wanna be able to do it by hand. I would love some tits/hints/tricks on how to do it. I have a few chisels and a cheap dove tail saw.
-- I'd be done by now if I knew what I was doing! - said by no man ever with a woman present
5 replies so far
View TheFridge's profile
TheFridge
10814 posts in 1720 days
#1 posted 10-22-2018 02:14 AM
Learn how to cut to a line with out having to pare to the line. Sawing is the key to hand cut joinery. Mark scrap with a bunch of 90 degree lines on end grain and face grain and practice sawing on each side of the line without going over.
View AlaskaGuy's profile
AlaskaGuy
4979 posts in 2543 days
#2 posted 10-22-2018 02:16 AM
I’m at about the same point as you are.
There are a ton of guys on LJ’s that will help. They are helping me.
See this thread. http://lumberjocks.com/topics/292529
Also YouTube has a ton of videos on had cut dovetails. I’ve watched a bunch of them in the week or so. Visual learning it a big help.
AlaskaGuy
#3 posted 10-22-2018 02:25 AM
- TheFridge
ve been doing this every day, it helps
There are some good tip on hand sawing in this video
https://youtu.be/rMKseOkhcqg
TheFridge
#4 posted 10-22-2018 02:26 AM
It’s not a bad thing to try dovetails. The bad thing is that you spend a lot of time marking instead of cutting.
View Aj2's profile
Aj2
1941 posts in 2032 days
#5 posted 10-22-2018 03:19 AM
Here’s a tip. Pick wood for the pins that’s harder then the tail board.
Super soft wood like pine are difficult to chop your baselines nice and clean.
Poplar, soft maple,cherry, walnut are good choices.
Almost forgot to mention Alder for the homies ::)
The saws handle should feel nice in your hand. If your saw cuts to the left point 2 fingers out toward the blade before you change the set. On the teeth
-- Aj
