Need pulley set for Delta drill press
Forum topic by CodeDaddy posted 10-21-2018 10:07 PM 415 views 0 times favorited 9 replies Add to Favorites Watch
View CodeDaddy's profile
CodeDaddy
3 posts in 433 days
10-21-2018 10:07 PM
Topic tags/keywords: delta drill press pulley parts
Hello,
Unfortunately for me, I had to store my Delta 17-900 drill press in a pole barn for a few years. Mice decided the pulley housing made a nice home and built a big nest in there. Now the three pulleys are quite rusty and I would like to replace them. But the Delta part numbers 1312027, 1312024, and 1312020 for the pulleys don’t seem to be available anywhere.
Does anyone know where I can purchase comparable pulleys for this drill press? Aside from the rusty pulleys, it still works OK. I shouldn’t have to junk the drill press just because of three rusty pulleys.
Thanks in advance for your replies and help.
9 replies so far
View MrUnix's profile
MrUnix
7107 posts in 2438 days
#1 posted 10-21-2018 10:17 PM
Rust is easy to remove… save your money – clean them up and start using the machine again.
View Kazooman's profile
Kazooman
1268 posts in 2192 days
#2 posted 10-21-2018 10:26 PM
What Brad said. Get a jug of Evaporust and your pulleys should be just fine.
However, welcome to the reality of non-existent Delta parts. This is a common theme for older Delta machinery. The real problem comes when a non-standard part breaks. Tine to get out the JB-Weld!
View EdDantes's profile
EdDantes
48 posts in 150 days
#3 posted 10-21-2018 10:27 PM
Check McMaster-Carr:
https://www.mcmaster.com/v-belt-pulleys
You’ll need to know the bore size (may need to get out your calipers) and the step sizes.
View GR8HUNTER's profile (online now)
GR8HUNTER
5396 posts in 952 days
#4 posted 10-21-2018 11:37 PM
with evaporust soak overnight ……. pulleys will look brand new :<))
View Steve's profile
Steve
825 posts in 822 days
#5 posted 10-22-2018 04:18 PM
I had a very hard time finding a new pulley for my old Delta 15-270. Ended up taking a chance on one with the same # of steps and for the motor end on Ebay and it fit. But it was the only one I could find anywhere.
I agree with the others to just remove the rust.
View oldnovice's profile
oldnovice
7380 posts in 3607 days
#6 posted 10-22-2018 05:50 PM
Remove the rust, pocket the change required for new pulleys?
Kazooman
#7 posted 10-22-2018 06:10 PM
Here’s a picture I (tongue firmly placed in cheek) put together to convince a friend to try Evaporust. A Delta saw I got from Crainslist. I didn’t dip the entire plate, I laid some paper towels on it, poured on some Evaporust and wrapped in plastic overnight.
CodeDaddy
3 posts in 433 days
#8 posted 11-02-2018 11:17 PM
A hearty thank you to all who responded to my request. I learned something new – never heard of Evaporust. So I bought a gallon. That stuff is amazing! Awesome! Here are before and after pix of one of the pulleys.
A question: Would it hurt to paint with Rust-Oleum primer then gloss black? Or should I just leave them alone?
Another question: When re-attaching the spindle pulley, should the joint be lubed with oil or grease or left dry?
MrUnix
#9 posted 11-02-2018 11:26 PM
Won’t hurt anything… but the paint will wear over time with use. I personally would just shine them up . Easy way is to put it on the motor (or mount on a drill, or lathe, or …), turn it on, and hit the pulley with some sandpaper while spinning. Doesn’t take much to get them looking shiny new.
- CodeDaddy
Again, it won’t hurt anything to put a thin layer of oil/grease on the inner bore of the pulley when re-installing, but most people just leave them alone.
