Problem with Excalibur EX-21
« back to Scrollsawing forum
Forum topic by newsawontheblock posted 10-21-2018 03:49 PM 862 views 0 times favorited 9 replies Add to Favorites Watch
View newsawontheblock's profile
newsawontheblock
4 posts in 86 days
10-21-2018 03:49 PM
Topic tags/keywords: scroll saw help excalibur problem
Recently I upgraded to an Excalibur EX-21 scroll saw.
However, the saws upper arm will not lift unless I tug on in with both hands. It is very, very stiff!
What can I do to make this lift smoothly and easily?
9 replies so far
View Kazooman's profile
Kazooman
1264 posts in 2186 days
#1 posted 10-21-2018 04:31 PM
Contact the manufacturer.
newsawontheblock
4 posts in 86 days
#2 posted 10-21-2018 05:44 PM
Thank you Kazooman.
I discovered that the three bolts at the back were tightened way too hard.
I loosened them and oiled between the arm and the metal sides.
Everything works great now.
View tomsteve's profile
tomsteve
896 posts in 1453 days
#3 posted 10-21-2018 05:53 PM
shouldnt need any oil on any part of the EX. theres a set screw on the right hand back with a locking nut on it. thats the adjustment for the arm.
go down to the “maintenance,adjustments, and servicing” section in the owners manual
https://www.axminster.co.uk/media/downloads/505078_manual.pdf
newsawontheblock
4 posts in 86 days
#4 posted 10-21-2018 06:08 PM
Thanks tomsteve, I played around with that screw, and if anything it only made it even stiffer.
good to know that the EX should not required any oil. thanks
tomsteve
#5 posted 10-21-2018 07:50 PM
thats pretty strange those bolts would be too tight. is it a true EX or a clone?
newsawontheblock
4 posts in 86 days
#6 posted 10-21-2018 11:45 PM
It’s a true EX
Possibly someone new at the factory who doesn’t know how tight is right.
tomsteve
#7 posted 10-23-2018 12:36 PM
ya may want to look into pegas blade clamps for it. ive had my ex 16 for 4 years now and finally stripped the upper blade clamp. got a set of pegas clamps and they make blade changes/clamping a breeze.
get em here if youre in the US
https://qtena.com/b-pegas-head-clamp-set-br-for-axminster-carbatec-excalibur-excelsior-jet-king-pegas-and-seyco-scroll-saws-p-9607.html
or here if in canada
https://www.bearwood.com/pegas-chuck-head-replacement-kits.html
View Redoak49's profile
Redoak49
3731 posts in 2222 days
#8 posted 10-23-2018 01:15 PM
Putting in new blade clamps will have nothing to do with the problem he is describing.
I would contact Seyco who also sells them and is very knowledgeable.
tomsteve
#9 posted 10-23-2018 04:30 PM
- Redoak49
i wasnt insinuateing new blade clamps would solve the problem at hand, which was solved.
ray is knowledgeable, but doesnt sell excaliber any more.
