I'm stuck on an idea!
Forum topic by TheTimberAlchemist posted 10-20-2018 08:55 PM 453 views 0 times favorited 5 replies Add to Favorites Watch
View TheTimberAlchemist's profile
TheTimberAlchemist
19 posts in 94 days
10-20-2018 08:55 PM
Topic tags/keywords: using brass rods
I am trying to create a project where 5 or 6 brass rods are inserted perpendicular to a 12” square x 1/2” thick wooden base, most likely high quality plywood. The goal is to insert the rods and allow them to be removable. In order to make it stronger I was thinking of using t-nuts to insert the rods in for stability. But I’m not sure the threads of a t-nut would eliminate a wobble in the rods. Is there a better product I just can’t think of? The concept of a t-nut is perfect but I can’t find non threaded ones anywhere.
5 replies so far
MrUnix
7114 posts in 2439 days
#1 posted 10-20-2018 09:03 PM
Flange bushing/bearings or something similar maybe?
View wuddoc's profile
wuddoc
326 posts in 3958 days
#2 posted 10-20-2018 09:24 PM
TheTimberAlchemist
19 posts in 94 days
#3 posted 10-20-2018 09:41 PM
You guys are brilliant! I was searching everywhere for these without luck! Thank you much, I’ll post the finished product for you to see it in action
View waho6o9's profile
waho6o9
8539 posts in 2817 days
#4 posted 10-20-2018 10:15 PM
Awesome
View bondogaposis's profile
bondogaposis
5155 posts in 2592 days
#5 posted 10-20-2018 10:25 PM
If you thread the ends of the rods so that they screw into the-nuts, they won’t wobble.
-- Bondo Gaposis
