Finding stock inserts is going to be difficult for that machine, but making them is easy - particularly since you already have a lathe. There are plenty of ways to make them, but for the lathe, you just turn down whatever material you want to make the insert out of to a 3" diameter cylinder, then slice off as many as you want. I also like to make them out of recycled milk jugs, which is a bit stronger and flex-resistant than wood, but just as easy to work.
I have a 16" Grizzly. I considered making aluminum inserts,then decided to make a 1/4" table top over the existing table. I made it big enough to extend my current band saw table top and now I have a nice smooth replace able work table.
wkndwrnch's idea for an auxiliary table has the advantage that you can have nearly a zero clearance surround to your blade. I usually make mine out of hardboard/masonite. Of course eventually the hole gets too big, so you have to toss (or repurpose) the old one and replace it. Cleats around the perimeter keep it from wandering around. Just saw to the middle of the auxiliary table and stop. No need to drill a hole.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
