Pine table starting to cup. Help!
Forum topic by Scotsdevil posted 10-20-2018 02:29 PM 489 views 0 times favorited 9 replies Add to Favorites Watch
View Scotsdevil's profile
Scotsdevil
4 posts in 93 days
10-20-2018 02:29 PM
Topic tags/keywords: question pine
A few weeks ago i built a 10 foot pine dining table however the edges are starting to bend upwards slightly and I’m worried it might get worse over time. The construction is 5×10 foot boards each 2” thick and 7” wide. The boards have full length tongue and grooves and are glued together. The table sits on two trapezium metal legs.
Is there something i can do now that will stop further movement?
Thanks in advance
A novice, self taught, wood worker
9 replies so far
View bondogaposis's profile
bondogaposis
5153 posts in 2591 days
#1 posted 10-20-2018 02:34 PM
Did you use construction lumber?
-- Bondo Gaposis
Scotsdevil
4 posts in 93 days
#2 posted 10-20-2018 02:45 PM
I think so it was from a timber supplier. Its Scandinavian pine that was kiln dried. Moisture content was around 14% when i began working on it.
- bondogaposis
- bondogaposis
Smitty_Cabinetshop
15822 posts in 2858 days
#3 posted 10-20-2018 02:51 PM
Thanks in advance
- Scotsdevil
Scotsdevil, there are several truths in woodworking and none more important that this one: Wood moves.
Doesn’t matter if it’s dried for 75 years, wood has to move. Especially cross-grain, as you’re finding out. Bondo’s question speaks to construction lumber being kiln dried OR stored outdoors OR not being fully acclimated to conditions (temp and humidity) found in the room in which the table will live.
You can plane it smooth, but until it’s done with the ‘big moves’ the wood wants to make, resistance is futile. And then, when it is planed smooth, air will get to the wood and it will move again. Large furniture projects featuring solid wood are sometimes brutal teachers.
Others will certainly add their inputs. Sorry I wasn’t more positive, you’re facing a serious challenge.
Scotsdevil
4 posts in 93 days
#4 posted 10-20-2018 02:56 PM
Thanks for the leason smitty appreciate your honesty. I guess i will wait and see what happens after a few months and hope for the best!
Thanks in advance
- Scotsdevil
Doesn t matter if it s dried for 75 years, wood has to move. Especially cross-grain, as you re finding out. Bondo s question speaks to construction lumber being kiln dried OR stored outdoors OR not being fully acclimated to conditions (temp and humidity) found in the room in which the table will live.
You can plane it smooth, but until it s done with the big moves the wood wants to make, resistance is futile. And then, when it is planed smooth, air will get to the wood and it will move again. Large furniture projects featuring solid wood are sometimes brutal teachers.
Others will certainly add their inputs. Sorry I wasn t more positive, you re facing a serious challenge.
- Smitty_Cabinetshop
View jmos's profile
jmos
905 posts in 2609 days
#5 posted 10-20-2018 04:14 PM
As Smitty said, the best dried lumber is going to move with changes in humidity. What you are trying to do in a good design is allow for that movement.
With a table top there are a few time tested methods for trying to keep the top flat and still let it expand and contract across the grain (movement in the thickness isn’t usually an issue, but does happen, , and movement along the length is usually negligible.)
You can use an apron, where you use a fastener (buttons or Z clips are common) that will secure the top to the apron. You would typically fix the top (on the edge running across the grain) in the center, and then allow the fasteners to slide back and forth toward the edges of the table. Whether it’s on long or short edges depends on how the grain is running in your tabletop. The sides that run with the grain of the board need to be allowed to slide in and out, as the table expands. When done correctly, you hold the top tight to the aprons, and flat, and constrain the motion, but you can’t stop it.
Battens are another method. You run the battens across the grain, then fasten the top tight in the center and allow the fasteners to move toward the edges. This is typically done by making the holes in the batten a slot, instead of a round hole. In your case, if you have metal legs that include a horizontal piece under the table, you may be able to use additional fasteners to hold the top down, just slot the holes so the top can still move, or something will give.
Battens can also be installed in the bottom of the table top using a sliding dovetail joint, or a tapered sliding dovetail joint.
You can also add breadboard ends to try to control cupping. If you’re not familiar with this Google and Youtube can help. Again, it’s usually fixed in the center, and allows movement out toward the edges. This only really works if the grain on the table is running with the length of the table.
Good luck.
-- John
Scotsdevil
4 posts in 93 days
#6 posted 10-22-2018 12:06 PM
Thanks for the advice jmos I will attempt some this weekend
View Richard Lee's profile
Richard Lee
213 posts in 1015 days
#7 posted 10-22-2018 05:48 PM
Did you alternate the grain pattern ?
View AZWoody's profile
AZWoody
1420 posts in 1464 days
#8 posted 10-22-2018 06:20 PM
- Richard Lee
With 7” wide boards alternating won’t do much. Each board is wide enough that the cupping will happen to each one. Even with alternating boards, the table will look like an oversized corrugated sheet.
I haven’t had an issue with grain alternations or kept the same as long as the wood is acclimated and prepped right.
I think the problem here is wood that wasn’t dried enough yet and still has a way to go.
Richard Lee
#9 posted 10-22-2018 10:31 PM
If you glued a bunch of 7” wide boards together without alternating the grain its going to cup almost regardless of moisture content.
Yes you will end up with a corrugated panel but it should even itself out.
Yes wet wood will always be a problem.
- Richard Lee
With 7” wide boards alternating won t do much. Each board is wide enough that the cupping will happen to each one. Even with alternating boards, the table will look like an oversized corrugated sheet.
I haven t had an issue with grain alternations or kept the same as long as the wood is acclimated and prepped right.
I think the problem here is wood that wasn t dried enough yet and still has a way to go.
- AZWoody
