| Forum topic by derosa | posted 643 days ago | 1120 views | 0 times favorited | 14 replies | ![]() |
643 days ago |
I’ve started shopping around for a benchtop mortiser and really don’t know which one to pick. I have an American woodworker that did reviews but the only one of the 6 that received a good buy stamp that I can find is the Jet JBM-5. I have a delta drill press and bandsaw and tend to lean towards it but none of my other tools are delta so it isn’t a deal maker and actual opinions help more. Other choices in this price range I should look at? I saw the craftsman one but the last three power tools I bought from them all sucked and failed so they’re out. Grizzly doesn’t seem to have one and Rockler only has the Jet model. -- --Rev. Russ in NY-- A posse ad esse |
14 replies so far
#1 posted 643 days ago |
I have a Powermatic tabletop mortiser for several years now and it is very precise, well built and a quality piece of machinery. I researched other available machines before I bought it and examined all of them before deciding. Great choice and lots of good features. -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#2 posted 643 days ago |
I don’t own a mortiser, but I was just reading an old copy of Woodworker’s Journal (AUG 2010) today where they did a review of a bunch of them, so I figured I’d mention what they had to say. Their “best bet” choice was actually the Shop Fox W1671. $239.99 With a 3/4hp motor, the only other one with that size motor was the powermatic, but it was almost twice the price. The Jet scored well, but they weren’t super excited about it due to some features that could be improved upon. The Delta scored well. The woodriver wasn’t reviewed. Also the wood whisperer did a video awhile back about mortisers in case you haven’t seen it yet. It doesn’t compare specifics, but maybe there’s some info in there that could help you make a decision. Hope any of this helps. |
#3 posted 643 days ago |
I have the Delta which I bought used and have been very pleased with it. I guess it depends on how much you are going to use it. Me, not so much but I know it works when I need it. It came with a bunch of bit/chisels of various sizes. I’m sure there are good deals out there if you are not in a hurry. Jack -- jack -- ...measure once, curse twice! |
#4 posted 643 days ago |
I have the Jet and I am reasonably pleased with it. However, if I had it to do over again, I am not sure I would bother with a mortising machine at all. I much prefer cutting mortises with a router and jig. In my case, I am a big fan of the mortise pal which is a loose tenon system. I like to think of the mortise pal as the “poor man’s domino”. It does almost everything a domino does but at a much lower price. I have experimented with many different approaches to M&T joinery. Previously, my mortising machine for the mortises and a table saw to cut the tenons was my standard approach. Now it is the mortise pal. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#5 posted 643 days ago |
I would agree with Jack that it depends on how often you would use it. In most home woodworker shops that I have seen it only collects dust under the bench most of the time, but if you are in a production shop and making a lot of M&T joinery, then go for the very best and easyiest to setup you can get without a thought to cost because it is going to save you time and make you money. |
#6 posted 643 days ago |
I bought a HF a couple of weeks ago and after cutting more than 40 1/2” mortises I have to say I’m satisfied. -- Don't rollerskate in a buffalo herd |
#7 posted 642 days ago |
I searched and researched for a couple of months for a machine, even used my neighbors delta for awhile to see how i liked it. I was at the local Woodcraft store and was talkng with the owner and he turned me on to the Woodriver and told me it was made by Steel City i purchased it and it came with 4 pretty decent chisels and assembly was a breeze. I startd using it that night and have to say i really ike it and would recomend it. |
#8 posted 642 days ago |
Thanks for all the replies. The Delta got a number of good reviews and I decided to go with it. I managed to find it on sale for 275.00 shipped and delta is running a 50.00 mail in rebate. -- --Rev. Russ in NY-- A posse ad esse |
#9 posted 642 days ago |
Russ, I suggest that you invest in some good quality chisel bits. There are many sources. I have some of these from Lee Valley and am very happy with them. I hope that you enjoy your new machine! -- I was walking down the street, something caught my eye, and dragged it 15 feet. |
#10 posted 642 days ago |
I think you’ll like the Delta. Looks like a good price too. See if “Vulcan” still makes chisels. They are well made. Don’t forget a sharpener too. Have fun. Jack -- jack -- ...measure once, curse twice! |
#11 posted 641 days ago |
I got the WoodRiver for Christmas last year. -- Those who insist it can't be done - should politely refrain from interrupting those who are doing it. |
#12 posted 641 days ago |
For the moment I was going to stick with the chisels it came with and get the sharpener that is used in the video above. I picked up an old, discontinued wood mag from around 2000 or 2001 that has a bit sharpening jig using the sharpener in the video. -- --Rev. Russ in NY-- A posse ad esse |
#13 posted 641 days ago |
Alas too late, but perhaps another person interested in mortisers will read this. When I was shopping, I noticed that Jet was the only one with a 1725 motor; the others were 3450. This may have changed since then (about 10 years ago). I bought the Jet because so much heat—the enemy of a sharp edge—can be generated at the tip of the cutters, and I reasoned the lower speed would be a kinder speed. Just my $.02. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#14 posted 641 days ago |
Lee – I made the same decision for the same reason about 5 years ago. However, I think that today, most of the mortising machines run at 1725. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15804 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
