Router Bit Profile
Forum topic by jasonf6174 posted 10-16-2018 10:42 PM 271 views 0 times favorited 3 replies Add to Favorites Watch
View jasonf6174's profile
jasonf6174
2 posts in 93 days
10-16-2018 10:42 PM
Topic tags/keywords: router bit router profile trim
Hi! I’m interested in replicating a trim profile and I cant find a router bit that will give me the profile I want. Can someone point me in the direction of where to look for the the name of the router profile in the attached photo? Is this a custom Moulding bit used to make this trim? I tried to gray out an area of the piece that I’m not interested in. Any help would be much appreciated.
Thanks,
Jason
3 replies so far
View KYtoolsmith's profile (online now)
KYtoolsmith
46 posts in 95 days
#1 posted 10-17-2018 12:50 AM
Do you need a long run this profile? I’m a bit old school and if only a short run, I would do it in two passes with two custom ground plane irons for my Stanley 45… No router bit needed. The old combination planes are amazing. We often forget that the unique profiles on old furniture and interior trim was done by hand.
Regards from Kentucky!
-- "Good enough" is just an excuse. Good workmanship needs no excuses.
View lumbering_on's profile
lumbering_on
578 posts in 724 days
#2 posted 10-17-2018 03:01 AM
I doubt you’ll find a router bit with that profile, but you can build it up. Stumpy Nubs made a good video on it. The only issue is that you’ll have to do some work to figure out exactly what you are dealing with. It also helps to have a tilting router lift.
https://www.youtube.com/watch?v=UYaU01gSBJE
jasonf6174
2 posts in 93 days
#3 posted 10-18-2018 05:44 PM
Thats what I was afraid of. I think i might just use a similar molding profile that I already have and call it done! Thanks for the advice!
Jason
