Applying spray on finish in this cold weather
Forum topic by Jim Finn posted 10-16-2018 09:40 PM 359 views 0 times favorited 3 replies Add to Favorites Watch
View Jim Finn's profile
Jim Finn
2688 posts in 3156 days
10-16-2018 09:40 PM
Topic tags/keywords: cedar finishing
I have an unheated finishing shed that I try to heat with a small electric heater. After spraying a light coat I would allow to dry four hours or overnight. I recently purchased a used heat lamp, that was used for automotive painting, and have reduced my curing time to fifteen minutes per coat. I am using a rattle can of finish. I applied five coats on four items today before lunch.
-- No PHD just a DD214 Website> craftingcouple.com
3 replies so far
View Jim Jakosh's profile
Jim Jakosh
21953 posts in 3340 days
#1 posted 10-17-2018 12:58 AM
Hi Jim. I know heat makes the difference. In cold weather I try to heat the part and the spray can somewhere- usually in the furnace room- and then spray in the shop. I find if either are cold, I get lots of runs and sags.
cheers, Jim
View msinc's profile
msinc
569 posts in 738 days
#2 posted 10-17-2018 01:02 AM
I find that if I run hot water from the sink over the spray can and shake it up every 10 or 15 seconds until I feel the finish itself hot in the can it sprays a lot better. This doesn’t really help it to dry faster, but it does for certain seem to help it smooth or “wet” out good and give a better application with little or no runs.
Jim Finn
#3 posted 10-17-2018 02:08 AM
Yes, I heat the rattle can in a can of hot water also.
