| Forum topic by Mike | posted 644 days ago | 617 views | 0 times favorited | 11 replies | ![]() |
644 days ago |
Topic tags/keywords: plywood joint I am thinking of making something from plywood and wanted to see if anyone has tried to joint the edge of a plywood board. Is this even worth the effort or is it going to shatter? Thanks, Mike -- look Ma! I still got all eleven of my fingers! - http://www.termitecrafts.com |
11 replies so far
#1 posted 644 days ago |
The plywood should be fine and get a nice smooth edge. Your joiner might suffer. I wrecked a set of knives jointing plywood. The knives left neat ridges in a board where they had hit the glue in the ply. -- Adversity doesn't build character...................it reveals it. |
#2 posted 644 days ago |
Mike -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 644 days ago |
I am looking to just use box store 3/4. I just need to clean up just two 4’ edges if I were to make the project -- look Ma! I still got all eleven of my fingers! - http://www.termitecrafts.com |
#4 posted 644 days ago |
Many of the box stores carry plywood made in China and has been found to have such things as razor blades or other metal in it,it also has been know to de laminate . So no matter what type of joinery you use it may not make a good project. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#5 posted 644 days ago |
I’d use the table saw and call it a success…clean up the edge with sandpaper. I just don’t see an application that would require a clean, jointed edge on regular plywood (baltic birch is a different story), at least not at risk of wrecking your jointer blades. If you don’t care much about your jointer plane, then you could use it. -- jay, www.allaboutastro.com |
#6 posted 643 days ago |
Don’t use the jointer with the expensive knives. Use a router and straight edge with a flush trim bit. Much cheaper to replace a bit rather than the knives. -- Sam Hamory - The project is never finished until its "finished"! |
#7 posted 643 days ago |
If I were convinced that plywood was the answer, the jointer would be in play. Just take the advice above and check the edge carefully first. And take light passes so you know what you’re biting into. The wisdom above says go another route… Hard to ignore… Hope you update us with whatever you decide. Good luck! -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive |
#8 posted 643 days ago |
Ok so I tried it anyway as sometimes you just need to see what happens. I was ripping the plywood into 2” strips and then face glueing the faces together for a special effect. Since I needed the edge clean and without saw marks I did 2 passes per board with the jointer and everything was fine. No damage to the blades that I could see after inspection. I also moved the fence several times so that I wasn’t using just one part of the knives. I will post the project when it is done. -- look Ma! I still got all eleven of my fingers! - http://www.termitecrafts.com |
#9 posted 643 days ago |
I’m not sure why, and didn’t even realize it until you asked the question, but I typically grab my dewalt hand planer when I joint plywood. Maybe I knew the above but didn’t know I knew it. I also tend to take very shallow cuts. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#10 posted 643 days ago |
I sometime find Columbia Forest ply at the big box..ask them if they have any. It is much better quality. -- “Socialism in general has a record of failure so blatant that only an intellectual could ignore or evade it” ― Thomas Sowell, The Thomas Sowell Reader |
#11 posted 642 days ago |
The glue is heck on jointer blades. Especially the Chinese plywood. They REALLY like putting tons of glue to compensate for the crappy veneer. Glue fixes everything… :-( -- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot" |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1535 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
