clamping and cauls station idea
Forum topic by Angela posted 08-18-2011 11:02 PM 3482 views 3 times favorited 8 replies Add to Favorites Watch
View Angela's profile
Angela
205 posts in 2770 days
08-18-2011 11:02 PM
I recently saw this on the Internet and thought it was a great idea. I thought I’d share it with the folks on LJ.
I was wondered if anyone has made something slimilar and would share their ideas and photos with us.
If anyone is interested where I discovered this clamping and cauls station it is located at a Wood Forum
I tried to locate the maker (brianalt) of this on LJ but it appears he’s not a member.
Angela
-- www.WoodWorkersWebsite.com - Helping other woodworker's
8 replies so far
View Bertha's profile
Bertha
13495 posts in 2567 days
#1 posted 08-18-2011 11:03 PM
It’s really clever but it eats up a lot of real estate. For a predictable glue-up in a mass produced piece, this would be a winner. Thanks for sharing it!
View DamnYankee's profile
DamnYankee
3301 posts in 2436 days
#2 posted 08-18-2011 11:13 PM
I was just thinking the same thing Bertha said.
-- Shameless - Winner of two Stumpy Nubs Awards
Angela
#3 posted 08-18-2011 11:13 PM
I thought the same thing about the size and it would have to be even larger if it’s a larger glue up. It wouldn’t be to bad if the cauls unscrew then they could be stored in the rafters but to store as a whole unit..Yikes
View Loren's profile
9769 posts in 3522 days
#4 posted 08-19-2011 12:32 AM
Those are splittable hinges.
View jusfine's profile
jusfine
2422 posts in 2800 days
#5 posted 08-19-2011 04:41 PM
Hard to tell from the photos, but it doesn’t appear that there is a slight crown on the cauls, if there is it may be absorbed by the cushiony rubber material, and that defeats the main purpose of a caul… in my opinion.
I have an adjustable Plano system I purchased quite a few years ago, one half of it fastenes neatly to the wall, not unlike the one picured, however, it is vertically mounted and works quite well. Saves “real estate”...
I use it mostly for efficient use of scraps and strips, slather glue on them, stick them in the clamp and leave them to dry. Useful for making tops for shop cabinets, shop jigs, etc. Can start with a few pieces, add some later, until I get to the size I need, then run through sander or planer.
There is a knuckle between the two vertical pieces that allows for clamping of material from 1/4” to 4” thick.
It can also be used as a veneer press.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
Bertha
#6 posted 08-19-2011 05:11 PM
I’ve seen the wall-mounted ones before with crowned cauls and they’re slick. If I had a free wall and I could talk myself out of a panel saw :) , I’d consider one.
jusfine
#7 posted 08-19-2011 05:20 PM
Al, you will get way more use from a Festool track saw than a panel saw… and still have room for a Plano! :)
Angela
#8 posted 08-21-2011 01:55 AM
jusfine – I saw something like that years ago at a woodworking show. I really loved it but I recall the price was way too high.
I don’t have the wall space either and I don’t do too many glue ups.
I’m making some cauls right now for my project.
