wiring
Forum topic by Karda posted 10-15-2018 04:21 PM 363 views 0 times favorited 7 replies Add to Favorites Watch
View Karda's profile
Karda
1382 posts in 790 days
10-15-2018 04:21 PM
Hi, I have to change a low voltage trance former. It is wired to a line coming from the wall switch. Being the wimp I am I usually turn the house current of but is in necessary since I can turn the switch of and I won’t be touching the switch Logic says if the switch is off it would be ok but I flunked logic what do you think thanks Mike
7 replies so far
View squazo's profile
squazo
120 posts in 1881 days
#1 posted 10-15-2018 04:49 PM
you could check it with a volt meter.
But you should kill the breaker anyways, Ive got a friend who got hit with 20 thousand volts and almost died.
120 can kill you too.
The switch could fail
Somebody could turn it on.
a bug could get in there and connect the contacts (this has happened and I have had to deal with the resultant fire)
It could have a secondary means of power
Just too many ways to get hurt.
View JohnMcClure's profile (online now)
JohnMcClure
395 posts in 877 days
#2 posted 10-15-2018 05:20 PM
Agreed. Kill power at a breaker, then check for dead with a meter. If you cant do that, get a pro.
-- I'd rather be a hammer than a nail
View William Shelley's profile
William Shelley
608 posts in 1705 days
#3 posted 10-15-2018 09:56 PM
I’m super paranoid, I always test my volt meter against a known live circuit before confirming that another circuit is dead. I wouldn’t want to end up on the floor because of a malfunction in a $15 tool.
That being said, electricity is dangerous but if you know the rules and pay attention, you shouldn’t have any accidents. I’ve done work in my main panel live before because I didn’t want to turn off the computer servers I run.
-- Woodworking from an engineer's perspective
View verdesardog's profile
verdesardog
171 posts in 2847 days
#4 posted 10-15-2018 10:50 PM
Trance former, that’s a new one on me. New age electronics?? LOL
Most likely transformer I guess. what is it conncted to that has a switch? You never know if the installer was qualified to do the wiring, I would check for voltage before doing anything with it.
-- .. heyoka ..
Karda
#5 posted 10-15-2018 10:56 PM
ok thanks I can turn it off
View lumbering_on's profile
lumbering_on
578 posts in 726 days
#6 posted 10-15-2018 11:26 PM
Standing on a plastic stool with rubber soled work boots and keeping one hand behind your back will prevent any issues. But a voltage meter usually suffices.
lumbering_on
#7 posted 10-15-2018 11:26 PM
Double post
