Please recommend a file for sharpening card scraper and tuning planes etc.
« back to Hand Tools forum
Forum topic by SMP posted 10-15-2018 04:18 PM 1334 views 0 times favorited 21 replies Add to Favorites Watch
View SMP's profile
SMP
178 posts in 143 days
10-15-2018 04:18 PM
Hello all,
I have some old files that seem to be either clogged with metal that brushing wont remove or are dull in spots. When trying to use on a new card scraper I got, it seems to miss some spots and then the card scraper isn’t perfectly flat. Went to Home Depot but there is a ton of options on what style and cut, etc. But then I read these Nicholson files aren’t as good now that they aren’t made in the USA anymore.
https://www.homedepot.com/p/Nicholson-10-in-Bastard-Cut-Mill-File-21839/100148489
Can anyone recommend something or is this one ok for filing card scrapers, and tuning planes etc?
Thanks,
Steve
21 replies so far
View BroncoBrian's profile
BroncoBrian
875 posts in 2196 days
#1 posted 10-15-2018 04:20 PM
I am afraid you just started something…
Good question though.
-- A severed foot is the ultimate stocking stuffer.
View TheFridge's profile
TheFridge
10816 posts in 1724 days
#2 posted 10-15-2018 04:29 PM
Nicholson’s are better than cheap trash files. They’re ok.
View JRsgarage's profile
JRsgarage
335 posts in 747 days
#3 posted 10-15-2018 04:31 PM
For the card scraper, take a look at the Veritas variable burnisher. It takes all the guess work out and very simple to use
-- Two is One, One is None
View Bill White's profile
Bill White
5148 posts in 4198 days
#4 posted 10-15-2018 04:52 PM
The burnisher will not replace a file.
I have been able to locate some USA-made single cut files at a local (old time) hardware store here in Tupelo.
Check around in your area to see if you have such a store. They might just have what you need.
Also, check out file sharpening and cleaning vids on YouTube. I use a piece of copper pipe and some white vinegar. The pipe really helps to remove the metal junk stuck in the files, and the vinegar will etch/sharpen the teeth.
You will need a stone or diamond plate to smooth the edge before burnishing and turning the burr on the scraper.
-- bill@magraphics.us
View SMP's profile
SMP
#5 posted 10-15-2018 05:17 PM
- JRsgarage
That does look appealing, I just looked at it Saturday, but $53 at my local shop, when I already have a Crown rod type burnisher is hard to justify.
View SMP's profile
SMP
#6 posted 10-15-2018 05:23 PM
- Bill White
Thanks for the tip, I’ll try out the youtube route to see if I can clean these old files I have.
View AlaskaGuy's profile (online now)
AlaskaGuy
4991 posts in 2547 days
#7 posted 10-15-2018 05:27 PM
Watch some YouTube videos on card scraper sharpening. Watch several not just one. There more that one way to skin a cat.
https://youtu.be/hq881txBKSw
https://www.youtube.com/results?search_query=card+scrapers+woodworking
BroncoBrian
#8 posted 10-15-2018 05:37 PM
Alaska Guy,
I did what you suggested and watched youtube videos about how to skin a cat. I am not sure how this helps…
Lol.
AlaskaGuy
#9 posted 10-15-2018 06:00 PM
Alaska Guy,
Lol.
- BroncoBrian
Sorry I couldn’t help
JRsgarage
#10 posted 10-15-2018 06:06 PM
I’ve never had issues just flattening and deburring on my granite and sandpaper and going straight to the burnisher…but, I’m sure there are more proper/technical ways to go about it
View MrRon's profile
MrRon
5264 posts in 3481 days
#11 posted 10-15-2018 08:19 PM
Use a single cut fine flat file and use it by draw filing, that is, by holding the file at 90° to the card and filing by pushing the file away from you. Hold the file with both hands. After filing, you will still have to form the cutting edge with a burnisher.
View SMP's profile
SMP
#12 posted 10-18-2018 02:04 PM
- Bill White
Wanted to thank you again for these tips. I made a scraper out of some scrap copper pipe i had and tht really helped. There was some builup of black powder(carbon?) that th file brush wasn’t helping with but the copper got out a bunch of it. I attached a pic so you can see this black gunk kind of caked up, this is after i removed most of it, the files are different colors now! Now they are sitting in a tub of vinegar for a couple days. (Pro tip: do NOT get vinegar on any cuts you have, ouch)
TheFridge
#13 posted 10-18-2018 02:27 PM
Alaska Guy,
Lol.
- BroncoBrian
Sorry I couldn t help
- AlaskaGuy
I don’t know what to say. I don’t think funny quite covers it. I laughed like a little schoolboy.
Solid advice from bill
View shampeon's profile
shampeon
1894 posts in 2421 days
#14 posted 10-18-2018 02:52 PM
I cut a slot in an offcut 2×4 to hold the file at 90, and run the scraper against the face of the wood against the file. Most of the time I don’t bother burnishing: you can just start using it after jointing the edge.
AlaskaGuy
#15 posted 10-18-2018 05:45 PM
Alaska Guy,
Lol.
- BroncoBrian
- AlaskaGuy
- TheFridge
Maybe you had too many
