Biscuits, Pocket Screws, T&G, or Other for Flat Surfaces?
« back to Joinery forum
Forum topic by MJClark posted 10-15-2018 12:37 PM 1148 views 0 times favorited 16 replies Add to Favorites Watch
View MJClark's profile
MJClark
34 posts in 126 days
10-15-2018 12:37 PM
What is your favorte method to join wood to create a large flat surface such as a table or desk top? In the past I have gone with T&G or Pocket Screws. I was reading that biscuits don’t add much in strength compared to a traditional face joint glued up. Last time I used pocket screws it worked ok and while I think it would be fine if you are only seeing one side, I would not want to do it for a project where both sides are visible. I don’t have a biscuit cutter but I have used a slotted router bit after seeing how a custom cabinet manufacturer was doing it. They noted it speeds up the process as you only need to line them up in one direction.
What is your preferred method and why?
16 replies so far
View LittleShaver's profile (online now)
LittleShaver
457 posts in 861 days
#1 posted 10-15-2018 12:40 PM
Glue.
-- Sawdust Maker
View rwe2156's profile
rwe2156
3237 posts in 1722 days
#2 posted 10-15-2018 01:41 PM
Glue provides more then enough strength.
I generally don’t use anything, but sometimes it is necessary, for example a slightly bowed board that you can’t joint. In that case, dowels or Dominoes are the best option. You can also cut slots and use short splines (be sure to orient them 90° to grain direction of panel). Biscuits don’t work as well for this purpose IME.
View bondogaposis's profile
bondogaposis
5155 posts in 2592 days
#3 posted 10-15-2018 01:44 PM
Just glue and cauls for alignment.
-- Bondo Gaposis
View CharlesA's profile
CharlesA
3361 posts in 2039 days
#4 posted 10-15-2018 02:01 PM
this is my method.
Glue.
- LittleShaver
View HokieKen's profile
HokieKen
7637 posts in 1380 days
#5 posted 10-15-2018 02:09 PM
Definitely glue. I use biscuits occasionally depending on what the piece is for but they are solely used for alignment and aren’t relied on for any bond strength.
-- Kenny, SW VA, Go Hokies!!!
Gerald Thompson
1143 posts in 2476 days
#6 posted 10-15-2018 02:37 PM
Glue.
-- Jerry
View Lazyman's profile (online now)
Lazyman
2711 posts in 1628 days
#7 posted 10-15-2018 02:55 PM
Biscuits are very easy and do help with alignment but you are right, they don’t add much strength. A plain glue joint is plenty strong anyway. IMO, the only thing a pocket screw might do is help apply a little more pressure during glue up if you don’t have enough clamps. I did used the once to join 2 relatively short pieces of laminated particle board because I didn’t think that would glue up very well. T&G or a spline will add more glue surface area and should improve alignment but you have to be more exact with cutting them. Any warpage will make that more difficult so are probably more trouble than they are worth. T&G is good for breadboard ends though.
View johnstoneb's profile
johnstoneb
3072 posts in 2414 days
#8 posted 10-15-2018 03:02 PM
Glue, sometimes biscuit to help with alignment even that is very rare.
-- Bruce, Boise, ID
View ArtMann's profile
ArtMann
1220 posts in 1057 days
#9 posted 10-15-2018 03:06 PM
If you can overcome the alignment problem, then glue alone is the best solution. For alignment purposes, I have used dowels and a precision jig as they are stronger and more accurate than biscuits.
View BroncoBrian's profile
BroncoBrian
875 posts in 2200 days
#10 posted 10-15-2018 04:36 PM
MJ
I love using Dominos. All you need is glue, hence the name glue-up. But the domino nearly guarantees that you will have a flat face each time. They fit snug and even. Even if your boards are not the same thickness (some reclaimed projects work out this way) you will have a flat face because the depth off the top face will be the same.
Or just glue.
-- A severed foot is the ultimate stocking stuffer.
View EarlS's profile (online now)
EarlS
2132 posts in 2589 days
#11 posted 10-15-2018 04:51 PM
Glue and biscuits. I actually prefer the Gorilla PVC (foaming) glue over Titebond. Biscuits every 8 ” help keep everything aligned and flat, especially if you are gluing more than 2 boards together or long boards.
View Jared_S's profile
Jared_S
101 posts in 200 days
#12 posted 10-16-2018 01:35 AM
Glue and cauls.
This was a nine board 133”x42” table top
BroncoBrian
#13 posted 10-16-2018 01:42 AM
Jared, you left out 136 clamps.
Jared_S
#14 posted 10-16-2018 01:50 AM
- BroncoBrian
Lol I use almost the same amount of clamps if I’m using biscuits, dominos or finger/glue joints.
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#15 posted 10-16-2018 02:19 AM
Glue.
- LittleShaver
Ditto
I might use biscuits for a thick glue up but for 2’x2’ or less I just roll with it. I use painters tape for thin 3/8 or less stock maybe even small 1/2 thick panels.
