Question about plane restoration
« back to Hand Tools forum
Forum topic by Manitario posted 646 days ago 1082 views 1 time favorited 23 replies Add to Favorites Watch
View Manitario's profile
Manitario
1862 posts in 1055 days
646 days ago
Topic tags/keywords: handplane restoration
I’ve started to restore a couple of hand planes and I have a few questions for those of you with more experience with this. First plane is a Stanley Bailey #4 type 12. I’ve been attempting to flatten the sole; how flat is flat enough?? I have read that the important parts are to have the toe, mouth and heel all flat relative to each other. Currently it appears that there is a very slight convexity to the sole, ie. the toe and heel are 0.002” and 0.004” out compared to the mouth. The other question regarding this plane is the edge of the mouth is not perfectly even; the pic demonstrates it better
Does this matter or should I keep taking metal off?
Second plane is a Stanley Sweetheart #5; the sole is surprisingly flat, but has several scrapes in it, again the pic shows this better than I can describe it. Does this matter; should I work these out?
I’m excited to get these planes working and to start using handplanes in my shop.
Thanks!
-- Rob, Sault Ste. Marie, Ontario
23 replies so far
View Bertha's profile
Bertha
13115 posts in 866 days
#1 posted 646 days ago
0.002-.004 would be just fine in my shop, as would the irregular mouth. I’m interested to see the comments below. They will determine whether I’m 1) practical or 2) a slob. ;)
Manitario
#2 posted 646 days ago
I’m all for being practical…as much fun as it is to sand a plane sole for hours…
14866 posts in 2391 days
#3 posted 646 days ago
When it’s all uniformly shiny, it’s done. That’s my theory, anyway.
View WayneC's profile
WayneC
9596 posts in 2270 days
#4 posted 646 days ago
I would agree the sole is flat enough. Your flat to the thickness of a typical shaving… Which side of the photo of the mouth is the front edge? Top or bottom?
Manitario
#5 posted 646 days ago
Hi Wayne; the front edge is bottom in the pic.
WayneC
#6 posted 646 days ago
Then I would say the mouth is fine…
View Don W's profile
Don W
9974 posts in 740 days
#7 posted 646 days ago
I’ve never measured mine. What a novel idea. :-)
I hit it with the sand paper until it touches all the relevant parts, which is what Charlie said I believe.Scratches shouldn’t effect it rememberer some are completely corrugated.
My true test….how does it work?
WayneC
#8 posted 646 days ago
Also, are you flattening the sole with the frog and blade in?
Manitario
#9 posted 646 days ago
yep, the frog/blade are in as I lap the sole.
WayneC
#10 posted 646 days ago
View wingate_52's profile
wingate_52
204 posts in 742 days
#11 posted 646 days ago
Place the plane on a flat surface, glass, does it spin, can you get a thin feeler gauge of piece of paper between the 2 surfaces? Do they prduce good shavings? It is not about being shiny, but areas of the plane need to be flat relative to each other.
View canadianchips's profile
canadianchips
1775 posts in 1170 days
#12 posted 646 days ago
Manitario. Sharpen the blade and make some shavings BEFORE you start lapping. Then make the sole shiny, flat or whatever YOU feel looks good. Make shavings again and compare the difference !
I think too many people are hyped up about the soles being flat, no grooves, etc. Here are 2 examples of planes that DO work. First is a compass plane, second a corrugated bottom plane.
In my own collection I remove the rust, clean the dirt off, if the jappaning is in poor shape I will repaint the bottom. My transitional I clean and sand the planes, put a new finish on the TOP and SIDES only, I wax the bottoms so they glide across the material smoothly. Repair any cracked or broken totes and knobs, shine up the brass parts and screws. HAVE FUN and Enjoy your restoration. (It’s satisfying and ADDICTIVE). I now look for the really roughest,poorest plane and see if I can bring it back to life. I never keep track of the time I spend doing it ! (I would never recover that time in money anyway) I retore them because “I CAN” and I enjoy it !
#13 posted 646 days ago
” It is not about being shiny, but areas of the plane need to be flat relative to each other.”
No, it’s not about being shiny. But if you take a plane with a patina on the sole and start lapping it on a flat surface, looking at the sole intermittently, once everything is shiny, it is flat enough.
Bertha
#14 posted 646 days ago
^agree with Charlie. Unless your plane’s been aggressively lapped on some kind of weird plane that’s not perpendicular to the sides; and everything’s touching down, you’re good to go (IMO).
wingate_52
#15 posted 646 days ago
A couple of mine. Stanley (U.K.) Nos.4 and 4 1/2, Both with Bubinga woodware. Smoothcut Japanese laminated Blue steel blades with Quangsheng chipbreakers. I bought the No.4 1/2 in 1968. A few handles/totes and knobs under construction.
