newbie question #2 - S
Forum topic by klinkman posted 10-14-2018 06:19 PM 469 views 0 times favorited 18 replies Add to Favorites Watch
View klinkman's profile
klinkman
25 posts in 115 days
10-14-2018 06:19 PM
Topic tags/keywords: finishing mistake
Thanks to those who chimed in on my earlier post about my walnut sofa table top. I wrapped up the construction this week and really like how this project is progressing. However I’m having another heart-burn moment.
For finishing, I’ve progressively sanded to 220 grit. I tested a couple of different combinations, and then settled on minwax “pre stain conditioner” and minwax “special walnut 224” stain. I really like how it’s come out, the grain an character are popping and it’s a great color. My idea at this point was just to apply a paste wax finish. I applied a single coat. The surface has turned luxuriant and silky smooth.
The problem I’m having is this: Before the stain was dry, a wayward bead of sweat fell on to the top. The piece was angled, so it rolled and made about a 4” streak that I didn’t notice until the next day. So sanded and followed up with a light reapplication of stain. Sanding just basically dulled the finish in the affected area. I thought covering it with wax might bring the luster back. It didn’t and I’ve got a mark now.
It’s not so noticeable looking straight down:
But it is when the light hits it:
My idea now is to just strip the top back down to bare wood and simply refinish the top. The question is what’s the best way to remove the finish?
I’m thinking mineral spirits to remove the wax, then either chemical stripper or sanding (or both) for the color? How about the sanding sealer, does that have to be fully removed? I’ve searched and can’t really find something leading in the right direction here. Thanks in advance, any thoughts are appreciated.
-- Klinkman, hand tool enthusiast
18 replies so far
klinkman
#1 posted 10-14-2018 10:40 PM
Well, the answer is sanding is simpler than I expected. The finish doesn’t penetrate very deeply.
View OSU55's profile
OSU55
2033 posts in 2229 days
#2 posted 10-15-2018 12:04 PM
I dont consider paste wax a finish. Not much protection from anything. A very easy finish – mw poly thinned 1:1, keep the surface wet for 10 min, wipe most of it off. Repeat, as many times as you want. Not as good as a thicker film but will be much better than just wax.
klinkman
#3 posted 10-15-2018 03:49 PM
Thanks OSU55. While I appreciate wax is not as durable as a poly coat, I consider this piece a bit of fine furniture, not for setting a wet drink glass on. :) Not that it ever won’t get a wet drink, but the idea of a simple to execute, nice looking finish that allows the feel of the wood (over a plastic barrier) was a reasonable trade off over durability for my first real piece of furniture. This will be a low traffic display piece, and yes, I understand it will require occasional refreshing. Appreciate your input and finishing technique, and will certainly try it down the road.
View Rich's profile
Rich
4012 posts in 829 days
#4 posted 10-15-2018 04:01 PM
To say that wax isn’t a finish flies in the face of every finishing book I have. While being at the bottom of the list for durability and protection, it’s certainly a suitable finish for pieces that will be used like klinkman just described.
View BroncoBrian's profile
BroncoBrian
875 posts in 2198 days
#5 posted 10-15-2018 04:07 PM
I love using wax as a finish. There are some great waxes available with color in them and they hold up well. I’ve used a dark wax for a sofa table recently and it was one of the most forgiving finishes I’ve used.
Nice work. Amazing how easy a ROS takes your finish off! I 1/8th chamfer on the table would look great.
-- A severed foot is the ultimate stocking stuffer.
klinkman
#6 posted 10-15-2018 04:24 PM
- BroncoBrian
Thanks Brian. 1/8” chamfer—exactly what I did after I got the finish off! Great minds. . . . ;)
BroncoBrian
#7 posted 10-15-2018 04:38 PM
Nice. For some reason, the light plays off that angle nicely on Walnut. And Purpleheart. It is a bit more modern.
View bondogaposis's profile
bondogaposis
5153 posts in 2591 days
#8 posted 10-15-2018 04:45 PM
You found out how un-durable a wax finish is, a drip sweat caused problems, sand back and apply some poly. Table tops see all kinds abuse, you’ll be refinishing that frequently.
-- Bondo Gaposis
klinkman
#9 posted 10-15-2018 05:17 PM
You found out how un-durable a wax finish is, a drip sweat caused problems.
Sweat hit the stain, before the wax.
View Rich's profile
Rich
#10 posted 10-15-2018 05:24 PM
- klinkman
Besides, wax is the easiest topcoat to repair. Applying a fresh coat amalgamates with the previous coat creating one coat. There’s no such thing as wax build up.
bondogaposis
#11 posted 10-15-2018 05:34 PM
True, but it is not much of a barrier, once the wood underneath swells from contact with water, the repair becomes not so easy.
-- Bondo Gaposis
BroncoBrian
#12 posted 10-15-2018 05:35 PM
- klinkman
Besides, wax is the easiest topcoat to repair. Applying a fresh coat amalgamates with the previous coat creating one coat. There s no such thing as wax build up.
- Rich
He did not read carefully. You can get this stuff at Ace, it works great. Dark/Medium/Clear: https://www.amyhowardhome.com/products/dark-wax
View Rich's profile
Rich
#13 posted 10-15-2018 06:09 PM
- bondogaposis
Read the thread. Water isn’t an issue in his case.
OSU55
#14 posted 10-15-2018 06:24 PM
To say that wax isn t a finish flies in the face of every finishing book I have. While being at the bottom of the list for durability and protection, it s certainly a suitable finish for pieces that will be used like klinkman just described.
- Rich
Never said books dont consider it a finish, I stated I dont, since it provides about zero protection. For something that will never be touched, or at the other end of the spectrum some “chic” distressed beat up piece, ok. IMO a sofa table will be touched and have things placed on it, even in a showroom, therefore a different choice should be made. If the op wants to continue dealing with issues like he already has, thats his choice, but it would not be mine.
bondogaposis
#15 posted 10-15-2018 06:47 PM
- bondogaposis
Read the thread. Water isn t an issue in his case.
- Rich
From the OP, I predict just wax won’t hold up.
-- Bondo Gaposis
