| Forum topic by ClayandNancy | posted 640 days ago | 588 views | 0 times favorited | 4 replies | ![]() |
640 days ago |
I bought a PC 7518 with the knowledge that it might need bearings and/or brushes. How do you get the collet retainer off(part on end of shaft) to replace that bearing? |
#1 posted 640 days ago |
This link has an exploded schematic. Bearing is held on with set screw. I took my PC router apart and it needed a little persuasion. Good luck. http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/portercable/7518 |
#2 posted 640 days ago |
TimL I was able to get the set screw loose, your right quite tight. I’m looking at the other end, where the collet is. I think it might screw on but not to sure and which direction clockwise or counter-clock. |
#3 posted 639 days ago |
Hey Clay,
This may be a little late, and you have already taken care of the problem, Like you said ” I think it might screw on but not to sure and which direction clockwise or counter-clock. ” ,that is what I would think also. I have never changed a collet on a router, but I have changed a chuck on a drill, on a drill chuck there is usually a screw at the bottom of the chuck, the screw is reverse threads, because the drill goes in both directions and the router does not, so I don’t think you will find a screw. On a drill, after removing the screw you would chuck up a good size Allen wrench in the chuck and give it a sharp Wacke with a hammer in the counter clockwise direction, that will loosen the chuck. I believe tools like these always turn into the part so it won’t come loose during operation. So. . . . .. If i am thinking about it right the collet should come off in a counter clockwise direction. I would chuck up a sacrificially bit in the router put your shaft wrench on the shaft and a pipe wrench on the bit and try to unscrew it.
The brushes are soft graphite and the springs are kinda week any little burr will stop them in the holder, don’t be afraid to scrub the brushes against some 100 grit paper and make them a little smaller, forty fiving the corners helps too. -- Chips and Shavings/ see you at WWW.underconstructionlive.com |
#4 posted 638 days ago |
Hey dryhter Finally just went for it with my electric impact and it unscrewed counter-clockwise. Pulled the armature out of the housing to find that all the blades of the fan on the shaft are gone. That is what was making the noise, one of the blades was just bouncing around in the housing. I found the part on the PC website. Thanks for all the responses |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
