Wood Preservative CCB Type
Forum topic by dattashri posted 08-17-2011 08:58 AM 973 views 0 times favorited 0 replies Add to Favorites Watch
View dattashri's profile
dattashri
6 posts in 3350 days
08-17-2011 08:58 AM
Copper chrome Boron (CCB) is one of the best alternatives to CCA wood preservative.
CCB is approved by American wood preservers association and confirms to IS 10013-Part III (1981).
CCB is fix type water borne wood preservative which provides fine protection to various wood damaging insects and factors.
CCB is used in vacuum pressure method for best results.
CCB is very effective against wood borers, fungi, decay, marine orgasms and termites and protects wood for a long time which is highly exposed and is in ground contact.
CCB is safe to human being.
CCB is suited for exterior use where as Boric Acid treatment is suitable only for interior use. Due to its high leachability boric acid retains the natural color of the wood where as CCA gives an undesirable greenish yellow color to the wood.
The preservation is generally carried out by impregnation under pressure and vacumm in cylindrical chambers. In vacuum pressure process the timber is subjected to an initial vacuum followed by pressure treatment and a final vacuum. It is ideal for deeping process also.
Why CCB:
Broad spectrum activity.
Low mammalian toxicity.
Cost effective
Easy to analyze and to determine penetration.
Slows photo degradation by U.V. radiation and water.
Fungistastic and fungicidal.
Prevents fungal spore germination.
Reacts with many of the components on the fungal cell walls and within fungal cell walls.
Inhibilition of extracellular enzymes responsible for the destruction of lignocellulosic wood components.
-- Well known for wood protection and restoration
0 replies so far
