Why am I getting a concave edge on my skew chisel
« back to Woodturning forum
Forum topic by RalphCompton posted 10-12-2018 05:23 AM 533 views 0 times favorited 9 replies Add to Favorites Watch
View RalphCompton's profile
RalphCompton
86 posts in 2850 days
10-12-2018 05:23 AM
Topic tags/keywords: sharpening turning tools wolverine skew
Not sure what’s happening. I am very new at turning and sharpening turning tools. I have a slow speed grinder and the Wolverine set, including the skew attachment. I set the jig to get the correct bevel, set the butt end of the 1” skew in the appropriate socket, and move the skew left and right across the moving wheel. A few light strokes in the right pocket, an equal number of light strokes in the left pocket. I get a nice bevel on each side, but the edge is concave. Not a good thing. With the narrower skew chisels I don’t need to move them side to side to contact the wheel, and I get a straight edge. Been looking for an answer on you tube but no luck.
Ralph
9 replies so far
View Andre's profile
Andre
2216 posts in 2007 days
#1 posted 10-12-2018 05:33 AM
Is the grinding wheel flat, did you dress it? The bevel should have a slight concave dependant on wheel diameter.
View hairy's profile
hairy
2782 posts in 3733 days
#2 posted 10-12-2018 01:13 PM
It’s called hollow grind, caused by the shape of the grinding wheel.
-- My reality check bounced...
View LeeMills's profile
LeeMills
618 posts in 1502 days
#3 posted 10-12-2018 02:12 PM
What they said… unless..
you are not talking about the 40° cutting bevel but the 70° across the tool.
This video states a problem if you press too hard at each end, maybe you are pressing too hard in the center?
On my jig the cutting edge slides straight across so this is only a guess.
About 30 seconds in.
https://www.youtube.com/watch?v=ziejM7dcNUE
View Lazyman's profile
Lazyman
2631 posts in 1588 days
#4 posted 10-12-2018 05:30 PM
EDIT: I just noticed that you said concave. I was thinking Convex. I that is correct, then my comment probably doesn’t apply.
I assume you are saying that the straight edge now has a curve to it? Just how curved is it? I don’t have this jig but it would seem to me that the design would lead to a very slight curve simply because you are moving the skew in an arc against the wheel. It might be more pronounced if the wheel isn’t flat?
Also, a curve won’t hurt the cutting action of the skew. In fact, some people intentionally grind the their skew with a curve and claim it actually works better. I haven’t tried it yet myself but I have been thinking about regrinding one of my cheap skews into a curved edge to give it a try. Here is an article about how to do it.
RalphCompton
#5 posted 10-13-2018 03:19 AM
Thanks for the responses. Yes, new grinder, new wheel. Both wheels slightly out of round. Dresser will be ordered soon, after I get back in town.
I get a nice, hollow, grind on the bevel. Completely satisfactory. It’s the 70 degree across the tool that’s the problem. Convex would be fine, but I’m getting a noticeable concave edge across the tool. Not good.
After reading the responses, and staring at my jig some more, I suspect some operator error as well as the wheel needing dressing. I need to move the edge left and right across the wheel because the edge is longer than the wheel is wide. Incidentally, I get a nice straight edge when doing a smaller skew that completely touches the wheel. After I get back and dress the wheel I will try again and report back.
Lazyman
#6 posted 10-13-2018 10:52 AM
If that doesn’t fix it, a picture of the curve might help.
View PeteStaehling's profile
PeteStaehling
69 posts in 1321 days
#7 posted 10-13-2018 11:19 AM
A couple things…
First, if you use a pivot type rest like a Wolverine and use equal pressure across the grind on a flat face of the wheel you will get a radius equal to the length of the handle. So not a lot of convex curve, but some.
Second, I am not sure why you assume that a convex curve is a bad thing. There are a lot of different ways to grind a skew, but I find that I like my most used skews ground with a bit of a convex curve. I do have a couple skews ground dead straight and do use them for some things, but 90% of the time I grab the curved one.
I am not an expert so take all that for what it is worth, but it has worked for me and I have see it work for some turners who are much more experienced and skilled than I am.
View RobbieB's profile
RobbieB
11 posts in 425 days
#8 posted 10-13-2018 11:32 AM
He’s getting a concave edge, not convex. Seems like OP is moving the handle faster than the blade.
PeteStaehling
#9 posted 10-14-2018 11:54 AM
He s getting a concave edge, not convex. Seems like OP is moving the handle faster than the blade.
- RobbieB
OOPS sorry. I misread that. I am puzzled how that would even happen given the method he is using unless the wheel is worn and badly in need of dressing or maybe he is grinding the middle of the skew on the corners of the wheel off of the flat face.
