How do you Mortise and Tenon?
Forum topic by zindel posted 645 days ago 2493 views 0 times favorited 35 replies Add to Favorites Watch
View zindel's profile
zindel
229 posts in 820 days
645 days ago
I have seen close to a 100 ways people make mortise and tenons…okay so maybe not 100 but you know there are many different ways. Just wondering how everyone goes about it and why it seems to work the best?
-- If you can't fix it with a hammer, You've got an electrical problem.
35 replies so far
View NathanAllen's profile
NathanAllen
383 posts in 1314 days
#1 posted 645 days ago
I’m a bit of a lazy man.
Tenons
Dedicated tenon jig on tablesaw with dado blade
For wide stock I use fence standoff and miter guide
Mortise
Mortise machine, clean up with chisel
827 posts in 663 days
#2 posted 645 days ago
My favorite way is to cut the tenons on a table saw, and the mortises with a router/spiral bit. I’ve tried a few of the other methods, and these just seem to work out best for me.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View tctaylor79's profile
tctaylor79
44 posts in 764 days
#3 posted 645 days ago
Same as Nathan on the Tenons and my mortises are done with a mortise bit setup on the drill press.
-- Tim Taylor - GLT Woodworks
View Brandon's profile
Brandon
3764 posts in 1121 days
#4 posted 645 days ago
Tenons on the table saw or sometimes a router. Mortises by drilling holes and cleaning them up with a chisel. I dream about getting a mortising machine, though.
-- "hold fast to that which is good"
View pintodeluxe's profile (online now)
pintodeluxe
1750 posts in 983 days
#5 posted 645 days ago
Tenons with a dado blade on the tablesaw. Mortises on the benchtop mortiser.
zindel
#6 posted 645 days ago
tctaylor do you have one of those drill press mortise attachments? I was thinking about getting one of those but i would hate to damage my drill press or waste my money. I just do what brandon does for now but I always look for ways to improve.
View dbhost's profile
dbhost
4748 posts in 1402 days
#7 posted 645 days ago
I had been doing the drill holes / follow up with chisels thing on the mortises, but I recently got a mortising machine. I am cutting mortises in things that don’t need them now…
Tenons are done with a dado stack on the table saw. My saw has a sliding miter table and it makes cutting tenons a breeze…
View tbone's profile
tbone
252 posts in 1854 days
#8 posted 645 days ago
My tenons are done on the table saw AFTER I do the mortises with a plunge router and home made jigs. Up-cut spiral bits seem to be the charm for me. I’m a firm believer in the “sneak up on it” method of fitting the tenons to the mortises.
-- Kinky Friedman on gay marriage: "They should have the right to be just as miserable as the rest of us."
View mailee's profile
mailee
44 posts in 648 days
#9 posted 645 days ago
I also use a tennon jig on the table saw for shorter lengths. for longer lengths I use a dado blade in my RAS. I use a dedicated mortice machine for the mortices.
-- www.alanwilley.co.uk
View Grandpa's profile
Grandpa
2381 posts in 845 days
#10 posted 645 days ago
I am with Nathan. There are some that hand cut everything but I let the machines do the work for me. I do the adjustments for the machines.
View 000's profile
000
3352 posts in 787 days
#11 posted 645 days ago
How do I do it?
http://www.youtube.com/watch?v=s9vEcesi3H8&feature=related
Loose tenons.
-- When the moderator chooses sides, his site sucks.
View MedicKen's profile
MedicKen
1560 posts in 1632 days
#12 posted 645 days ago
Currently working on a maple workbench. Mortises were drilled out at the drill press with a forstner bit and then squared with hand tools. the tenons I have decided to cut but hand and fit with hand tools.
View Uncle_Salty's profile
Uncle_Salty
181 posts in 1243 days
#13 posted 645 days ago
Dedicated Mortiser.
I cut tenons several ways, depending on the size, speed needed, and degree of accuracy.
If I need pure speed and the size is small…i use the band saw. Works great, but not very accurate.
If I have medium size and need for speed, but I also need some level of accuracy, I used the miter gauge and dado head with a sacrifice fence on the table saw.
If I have a lot of tenons to do and they are the same size, and accuracy is critical, I break out the tenoning jig and set it up!
All three serve their purpose.
View Toolz's profile
Toolz
887 posts in 1912 days
#14 posted 645 days ago
Loose tenons milled on router table mortises made on horizontal router table.
-- Larry "Work like a Captain but Play like a Pirate!"
Beginningwoodworker
13225 posts in 1843 days
#15 posted 645 days ago
I use my Benchtop Mortiser for making the mortises, and my Unisaw for making the tenons.
-- CJIII Future cabinetmaker
showing 1 through 15 of 35 replies
