Loose dog holes.
Forum topic by dad2jj82 posted 10-11-2018 12:54 PM 546 views 0 times favorited 9 replies Add to Favorites Watch
View dad2jj82's profile
dad2jj82
41 posts in 1812 days
10-11-2018 12:54 PM
Hey fellas.Hoping you can help. I am using a festool 20mm boring bit in my plunge router. I am using this with the dominofix router jig. Here is my dilemma. The hole being created is around 20.20mm. This causes a very loos fit with the 19.90mm dogs. I bought the TSO close fitting dogs 19.98mm these are also loose.My question I guess is this normal. I would think for 65$ the festool bit would be more precise. Has anyone else had this situation?When I watch videos guys have a hard time pulling their dogs out. Mine have no resistance at all, unless I wrap the dogs with “shim” making them around 20.15mm. What do you guys think? I wonder if it’s me or the bit.Thanks fellas
9 replies so far
View Tedstor's profile
Tedstor
1678 posts in 2830 days
#1 posted 10-11-2018 01:04 PM
Have you measured the bit with a caliper? That would be my first move. However, I’d be shocked if the bit were THAT far out of spec.
Second, I’d check my router for run out.
View Lazyman's profile
Lazyman
2608 posts in 1585 days
#2 posted 10-11-2018 01:18 PM
Are you using a Festool router with that jig? Just wondering if they somehow made it so it will only work accurately with their own tools.
dad2jj82
#3 posted 10-11-2018 07:34 PM
Lazy man it is not a festool router. It is a brand new Milwaukee 5616-24 router with a 8mm collet and 30mm guide bushing.
dad2jj82
#4 posted 10-11-2018 07:40 PM
Tedstor. I have measured it and am getting 20.06mm with my harbor Freight calipers. Maybe a stupid question but should I return that bit? .06 seems to be pretty far out for such an expensive bit.
View lumbering_on's profile
lumbering_on
574 posts in 687 days
#5 posted 10-11-2018 11:34 PM
Where did you buy it? Is it a local store or from an online one? If it’s local, I’d go in and have them take a look at it. Otherwise, returning may be a good option if it was bought online.
dad2jj82
#6 posted 10-12-2018 12:06 AM
I bought it from toolnut.com. I think I will return it. I have read that others have had the same problem with the festool 20mm bit. Pretty disappointed to say the least. If you know of any other 20mm bit with tighter tolerance please let me know. Thanks for advice
View Kirk650's profile
Kirk650
576 posts in 946 days
#7 posted 10-12-2018 02:18 AM
I had loose bench dog holes. Finally turned bench dogs from some Osage Orange I had and fit them to the holes.
Rick Dennington
6294 posts in 3392 days
#8 posted 10-12-2018 03:08 AM
I think the first thing I would have done was practice making dog holes on some scrap wood before committing to the bench…...!! That way you would know for sure, and then proceed on, or not….!!
-- " At my age, happy hour is a crap and a nap".....!!
dad2jj82
#9 posted 10-12-2018 12:58 PM
Rick I did practice on scrap. Tried on both melamine and plywood at different speeds. No way I would want to ruin a almost complete project.
