T&J #108 WS Tractor
Forum topic by Jason1974 posted 10-11-2018 10:24 AM 342 views 1 time favorited 22 replies Add to Favorites Watch
View Jason1974's profile
Jason1974
46 posts in 464 days
10-11-2018 10:24 AM
Topic tags/keywords: model exhaust heat shield wood tj
Does anyone have any ideas how to make an exhaust heat shield to put on the exhaust stacks for the WS tractor. I want to add some detail. Thanks.
-- Jason, North Carolina, northcarolinawoodworker@gmail.com
22 replies so far
View crowie's profile
crowie
2612 posts in 2093 days
#1 posted 10-11-2018 10:37 AM
G’Day Jason,
Check out Bruce’s finished truck and his blog…Cheers
http://169.46.96.71/projects/392833
http://lumberjocks.com/htl/blog/125505
http://lumberjocks.com/htl/blog/92850
-- Lifes good, Enjoy each new day...... Cheers from "On Top DownUnder" Crowie
View Dutchy's profile
Dutchy
3080 posts in 2310 days
#2 posted 10-11-2018 11:33 AM
Do you have veneer? or can you mnake it? 0.8mm
Take a dowel a little bigger than the exhaust. Put the veneer in water and boil it. If it boils take the veneer out of the water and wrap it with strong tape around the dowel. Wait a day and remove it. Now you can glue it to layers and again put it around the dowel with tape. Let it dry and remove the tape.
-- https://dutchypatterns.com/
View MrRon's profile
MrRon
5085 posts in 3385 days
#3 posted 10-11-2018 03:58 PM
Take some heavy duty aluminum foil and glue it, shiny side out around a dowel of the size used for the stacks.
View GR8HUNTER's profile (online now)
GR8HUNTER
4705 posts in 854 days
#4 posted 10-11-2018 04:05 PM
I just used a dowel http://lumberjocks.com/projects/251986 HOPE THIS HELPS :<))
View LittleBlackDuck's profile
LittleBlackDuck
2000 posts in 963 days
#5 posted 10-11-2018 11:35 PM
Damn it… This takes me back a few years when we were touting a repository (finished up as a suppository) for hints and tips… at least htl indexed his tips… I just die mine :-)...
I personally avoid using non wood (that’s why I try to use my head [note double negative]) on my timber models.
Similar to GR8 above… however, somewhere I saw a build where there were 100+ 1/16” holes drilled in the ”shield” dowel… you would need to build some sort of indexing jig for the drill press.
GR8HUNTER
#6 posted 10-12-2018 12:07 AM
this is what Alex is talking about : http://lumberjocks.com/projects/97837 :<))
pretty cool but to hard for me LOL
LittleBlackDuck
#7 posted 10-12-2018 11:59 AM
- GR8HUNTER
Haven’t seen that one, however, have seen similar. You have prompted my brain out of neutral GR8... Was thinking it might be a job for lazer-man with ketchup (with and “S”) for my next build…
Jason1974
#8 posted 10-12-2018 09:31 PM
Thanks for all the help. I think I’m gonna try Duthcy’s approach. Going to boil some wood. Lets see how this turns out.
LittleBlackDuck
#9 posted 10-12-2018 09:55 PM
Thanks for all the help. I think I m gonna try Duthcy s approach. Going to boil some wood. Lets see how this turns out.
- Jason1974
J’1974, I may have misinterpreted your question. If all you are after is drilling through a dowel to insert another for the shield you might consider one of these sets,
If I remember correctly it was $125 on the Internet (probably cheaper in $US). In building models I have found the need for various different sized colettes. As you can observe I have only used a few (most are still in their wrapper), however, this is a metric set used for non-T&J projects and found them invaluable. Just the 3 used have justified their cost when I consider the time I wasted (and would in the future) trying to centre the dowel by other means.
Jason1974
#10 posted 10-13-2018 05:02 PM
that was on my xmas wish list. lol
GR8HUNTER
#11 posted 10-13-2018 11:48 PM
maybe Alex will buy you one for Christmas Jason WWOOOOO HOOOOOOOOO :<))))))))))))
Jason1974
#12 posted 10-14-2018 02:32 PM
Guys I finally figured it out. It took me 2.5hrs but I did it. The exhaust heat shield looks AWESOME!!! Now its time to do the other side. I might make a blog how I did it.
crowie
#13 posted 10-14-2018 08:28 PM
First class job sir.
You’ve done yourself and the Navy proud.
The truck is looking great too!
LittleBlackDuck
#14 posted 10-14-2018 08:47 PM
- Jason1974
Why wait… with all the different timezones and digressions on Christian holidays, it must be the 25th December somewhere in the world now!
- Jason1974
TTWOOMM (took the words out of my mouth)... looks awesome. A blog would do you proud.
GR8HUNTER
#15 posted 10-14-2018 09:05 PM
please blog this for us looks like a bit of chip out? or are my eyes going wacky? what drill bits do you use ? looking very very nice all around :<)))
