How do I choose the proper size boards?
Forum topic by Dave posted 642 days ago 532 views 0 times favorited 8 replies Add to Favorites Watch
View Dave's profile
Dave
33 posts in 1181 days
642 days ago
Topic tags/keywords: tip question milling resource
I am fairly new to woodworking and am picking it up pretty fast. The one thing I struggle with is starting out the project, primarily shoosing what lumber to buy. I have the normal big box stores around which don’t have a very extensive selection of wood( Poplar,oak,pine,cedar). I found one exotic hardwood supplier locally but with the tools I currently have I am stuck. I don’t have a band saw for resawing to size, I don’t have a planer or a jointer yet so I can’t buy rough lumber either. I am hoping to get a jointer and planer soon though.
How do you choose your lumber and how would you size your selection if I need to make lets say… some slats for plantation shutters at 3/4” X 3”? I love this website and love the family of woodworkers that always seem to want to help other fellow woodworkers. Thanks for helping.
8 replies so far
View bluepaulsky's profile
bluepaulsky
34 posts in 642 days
#1 posted 642 days ago
i would search the net you would need to ask for prepared or par not rough cut or sometimes they say sawn
-- pgray
View ShaneA's profile
ShaneA
3956 posts in 764 days
#2 posted 641 days ago
When I select a board for a specific project I try to think in terms of maximum yield. If you want to end up with 1×3, boards that are 6+ or 9+ inches could yield two or three strips with less waiste. You also may consider length and defects into your choice. Will knots or checks be in the way? Always try to buy extra, we all make mistakes, plus after a while you will start to build an inventory. Plus there is a chance with notice, your supplier could dimension it for you.
View BentheViking's profile
BentheViking
1134 posts in 730 days
#3 posted 641 days ago
Dave, Shane seems to begin to make a point, but I don’t know if it is fully explained for a novice such as yourself to understand. Lumber at a place such as a box store is sold in something called nominal sizes. Lumber from lumber yards are more likely (though not always) sold in actual sizes.
A 2×4 is actually 1 1/2” by 3 1/2”. Therefore on your project a 1×4 will give you a 3/4” by 3 1/2” piece which would be fine for one piece of what you need. A 1×6 will still only give you one piece. To get two pieces you would actually need a 1×8. The better way to save lumber is going to buy as long lengths as you can possibly handle so that you don’t have lots of short drop off sections.
On the other hand if you were looking to cut strips that are 1 3/4” wide then a 1×4 would only yield one section (you have to account for the saw kerf when you are cutting down lumber). A 1×6 though will give you 3 pieces.
It is a lot of organization and math, and takes quite a bit of practice to get it right. I always start planning projects on paper not just coming up with cut lists but sometimes going as far to draw up boards and actually show how I will get each piece. Good luck.
-- It's made of wood. Real sturdy.--Chubbs Peterson
BentheViking
#4 posted 641 days ago
I also should add if your shutters are going to be going outside you might want to be particular about your woods and look into things such as cedar or cypress and stay away from poplar, oak, or pine.
View David Grimes's profile
David Grimes
2114 posts in 805 days
#5 posted 641 days ago
FWIW, our local HD also has maple boards. also, the HD select pine is beautiful, yet the Lowe’s Select pine looks a grade or two worse than the HD. IDK why, but it’s a fact.
If you will determine your longest lengths needed for the project, you might find that you will have MORE waste in buying a longer board than needed. It goes both ways. I only sketch enough of the project to get my cuts list so that I can buy the materials nearly exact. I, too draw up boards and actually show how I will get each piece from them.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View Sawkerf's profile
Sawkerf
1776 posts in 1234 days
#6 posted 641 days ago
For me, it’s all about minimizing waste. For your shutters, I would get 1×4 stock which is actually 3/4” x 3.5” (Don’t even think about asking why, ok!! – lol). Rip to 3” and toss the skinny strip of waste.
View Dave's profile
Dave
#7 posted 641 days ago
Wow! This is great stuff. I knew I could get some help. Thank you so much. I do a lot of pricing and finding how to get the most out of my boards and the most economical way. The shutters are for indoor and I am probably gonna use poplar or prototype one out of mdf. Thanks again.
View ksSlim's profile
ksSlim
800 posts in 1056 days
#8 posted 641 days ago
per your example; needed 3/4×3” slats, a 1×10 is about 3/4×9 1/2”, rip 3” widths, depending on your saw kerf, not much waste. when purcahsing material, take a measuring device with you as well as a “cut list’ of rough and finished dimensions.
-- Sawdust and shavings are therapeutic
