crosscut sled question
Forum topic by ryno posted 08-16-2011 07:12 AM 2032 views 1 time favorited 6 replies Add to Favorites Watch
View ryno's profile
ryno
106 posts in 3657 days
08-16-2011 07:12 AM
Topic tags/keywords: jig question
I recently built a crosscut sled that I am really happy with. The cut in the middle is at 90 degrees to the table. I am now considering making another cut at 45 because I’m about to make some small boxes that have mitres at the corners. Does anyone else have a 90 degree and 45 degree cut on the same crosscut sled or do you have a seperate jig for the 45’s. I can’t really think of any reason not to go ahead and make the 45 cut as well. Thx for any feedback
-- It is better to keep your mouth shut and appear stupid than to open it and remove all doubt.
27250 posts in 3815 days
#1 posted 08-16-2011 11:09 AM
Ryno, here is a video that John Nixon produced showing how to build his version of the super sled. I built this one and it has proven to be invaluable for cross cutting and mitering.
From your question I would guess that you are considering cutting a 45 bevel in the sled. This will work but it will open up the kerf in the sled which could lead to greater tear out. The addition of mitering capabilities in John’s version allows mitering to be completed with the blade set at 90 degrees. So to answer your question my sled runs both cuts but with a separate jig for the 45s (and other angles that come up).
16274 posts in 4211 days
#2 posted 08-16-2011 03:11 PM
I built one recently (sorry, no photos handy) and added a removable 45 degree fence that can be placed on either side of the sled. So far it seems to be working out quite well.
View gfadvm's profile
gfadvm
14940 posts in 2683 days
#3 posted 08-17-2011 05:33 AM
If you are wanting to miter wider boards to build boxes, I would make a simple sled with a single runner rather than cutting another kerf in your existing sled. The miter fences for the super sled are for cutting picture frame type miters and wont cut miters like you need to build boxes. The reason you dont want to cut a 45 in your existing sled is that you will lose your zero clearance kerf and could create a wide enough gap for small pieces to fall into.
View ryno's profile
ryno
#4 posted 08-17-2011 05:54 AM
thx, thats kinda the answers I was expecting,
View Ken Fitzpatrick's profile
Ken Fitzpatrick
376 posts in 4017 days
#5 posted 08-28-2011 12:40 PM
I would agree with gfadvm. Doug Stowe has a wonderful book on making boxes and in it describes several easily built sleds needed for quick and accurate cutting. If you have a larger library around where you live, they may have it for lending. Mine didn’t so I purchased from Taunton Press. I’ve seen it on sale for $14.95 and it includes a great video.
-- • "I have noticed that nothing I have never said ever did me any harm."....... Calvin Coolidge
View Howie's profile
Howie
2656 posts in 2916 days
#6 posted 08-28-2011 03:37 PM
I built the Nixon version and am very happy with it.
I also built a smaller sled and ran it thru the saw with the blade tilted to 45 degrees for the kerf. I use this quite a bit for making small boxes.
-- Life is good.
