Opinions: SHOP FOX Oscillating Benchtop Drill Press 13in. Model# W1668
Forum topic by bmerrill posted 10-09-2018 06:00 PM 626 views 0 times favorited 2 replies Add to Favorites Watch
View bmerrill's profile
bmerrill
10 posts in 219 days
10-09-2018 06:00 PM
Topic tags/keywords: shop fox oscillating benchtop drill press model w1668 drill press
INO a drill press.
Looking at the SHOP FOX Oscillating Benchtop Drill Press — 13in., 3/4 HP, 120V, Model# W1668 which can sand as well. Any opinion for current owners are appreciated.
2 replies so far
runswithscissors
2843 posts in 2171 days
#1 posted 10-10-2018 03:18 AM
Drill presses aren’t so good as spindle sander because they aren’t really designed for prolonged sideways forces on the quill. I’d ask Grizzly tech support (Grizzly is parent of Shop Fox) about that. Maybe they’ve mitigated that somehow, since that is obviously how the oscillating DP is going to be used.
View Lazyman's profile
Lazyman
2526 posts in 1533 days
#2 posted 10-10-2018 01:29 PM
I’ve got one that I bought that was practically new at a discount off of craigslist about 4 years ago. It seems to work just fine though I don’t know if there will be some sort of issue over the long term. Hopefully they used bearings with a higher radial (?) rating to mitigate that. If they can make a bearing for a roller blade that can handle the sort of stresses they get, surely they can put a bearing in there that can handle a little side pressure. It is not like you need much that pressure to sand.
If you don’t have room or a budget for a dedicated oscillating sander, this is a nice compromise. The built in dust collection port for sanding is actually pretty effective.
