| Forum topic by jmaichel | posted 672 days ago | 886 views | 0 times favorited | 4 replies | ![]() |
672 days ago |
I just recently bought a Ridgid jointer off CL and took the knives out for cleaning. The problem is that I cannot seem to get them to lock back in. Not sure if I just not setting knife properly or what but it the jib just won’t lock down on the knife and its still loose after I tighten the jib all the way down. Any help is appreciated. Thanks, |
#1 posted 668 days ago |
I am not familiar at all with Rigid tools but I was wondering if there is a ‘handedness’ to the blades? Perhaps they have been flipped end for end or something. I’m assuming there is nothing in the seat for the blades and that the bolts are loose enough. Some photos may help? -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#2 posted 667 days ago |
You should be able to find an owners manual on Ridgid’s web site. This should help with your blade problem. If all else fails, contact a Ridgid service center in your area. They have been very helpful when I’ve had questions. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#3 posted 667 days ago |
Post the model number so we can look up the manual for ya. Some of the newer model jointers use jack screws to aid in the adjusting of the knife depth. -- Website is finally up and running....www.woodandwrite.com |
#4 posted 667 days ago |
I knew there was a reason I was afraid to remove the knives from my Ridgid jointer. Thats why I’m following this thread! I’ll check my manual tomorrow to see what it says about replacing knives. Mine is only 3 years old so it may be different model than yours. Doesnt sound like it is as easy as changing blades in my Ridgid planer. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
| Forum | Topics |
Woodworking Skill Share
8844 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15977 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2774 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6132 |
