I would like to share with you the way that I’m cutting frame members at 45°.
Instead of messing with angles and protractors, I used very accurate, dedicated triangle.
To compensate for very small deviations from 45° or 90° of the blade, I’m using the method of “Left” and “Right” cutting.
instead of locating the stop somewhere 3’ behind or relying on a pencil line, I’m using another same width piece to be used as “Limiter” or “Stop”.
One small problem with this set-up is: The triangle vertex is at the center of the kerf, so, when you cut the 45°, the saw blade will cut half of the kerf width, from the length and because we are cutting each member from both sides, each member will be shorten by one kerf width that you have to take into account when you cut the members length to “Final Dimensions”.
In simple words, If you are using a 1/8” kerf blade and want the frame to be 20” x 20”, cut your members to 20-1/8”, the 1/8” will be removed during the 45° cutting.
If you remember the post “Triangle, copy and past”, later, I used one of them instead of the plastic triangle (last 2 pics)
The pictures really helped me understand how this is done. I had previously cut all miters by using the miter saw. I also used the right and left method. By using your type of jig, I feel it will be more accurate and easier to do. Thanks again.
-- Fred Childs, Pasadena, CA - - - Law of the Workshop: Any tool, when dropped, will roll to the least accessible corner.
that’s an interesting thought.. because, today, we have the tools and look at the quality of the stuff that we buy in the big stores…. shameful really. Our ancestors must be really disappointed.
8797
224
28
61
82
1536
3553
15803
2038
496
2845
810
903
766
2740
1547
6163
