Tips & Tricks: Cutting Perfect Angles
Forum topic by MsDebbieP posted 08-14-2011 02:01 PM 29004 views 3 times favorited 30 replies Add to Favorites Watch
18615 posts in 4154 days
08-14-2011 02:01 PM
Topic tags/keywords: tips angle precision
What are your “tips and tricks” (and challenges) re: cutting/sawing wood on exact angles (ex. 90 degrees)
Gateway to all Tips & Tricks Topics
30 replies so far
View joey bealis's profile
joey bealis
177 posts in 2500 days
#1 posted 08-14-2011 02:06 PM
Never had any tricks to cut perfect angles just the basics. Good square wood and your tools set up right.
-- http://reclaimedbuilding.blogspot.com/
View Don Butler's profile
Don Butler
1092 posts in 3389 days
#2 posted 08-14-2011 02:11 PM
I use a sled on my table saw.
Check the angle on the miter saw frequently.
On other angles, (45, 22.5) I have fixed angle sleds.
My secret?
Never use the miter guage that comes with the saw.
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
View ajosephg's profile
ajosephg
1880 posts in 3555 days
#3 posted 08-14-2011 02:16 PM
Osborne miter gauge
-- Joe
View mainwoodworks's profile
mainwoodworks
112 posts in 2642 days
#4 posted 08-14-2011 02:21 PM
Take as long as it takes to set up your, table saw, radial saw, or chop saw. The closer the tolerance you can get it, the better the results will be. Check your angles with a drafting triangle. I use a 30 60 90 degree and a 45 90 degree triangle. They are not expensive and are very accurate.
As for the scroll saw, I find it easier to follow the pattern if it is printed in cyan or magenta. The contrasting color from the black blade, makes it much easier to see where the blade is on the pattern. I also have found that putting a screw in each corner (off of the pattern of course) helps me control the turning of a ganged project. And of course keep the bed of all saws waxed ( use “Mothers” wax).
Hope some of this helps
-- Measure twice, cut once, and hope for the best.
#5 posted 08-14-2011 02:22 PM
I was reading a book on Intarsia and they were showing how to put two pieces together and then cut them at the same time to create the “perfect fit”.
I’ve never done it so can’t be more specific than that.
Now that I think of it, I think someone had posted something similar a few years ago re: cutting two pieces at the same time to always have the perfect “angle” on matching pieces (regardless of what the angle is).
What is the “real” information for this? (As I’m relying on my limited memory and skills)
View BobTheFish's profile
BobTheFish
361 posts in 2546 days
#6 posted 08-14-2011 03:39 PM
Ms. Debbie, you do the same for veneers. Lay the one sheet over top the other both face side up, with the edges you want cut lined up, tape the sheets together, then cut through both sheets at the same time. What it does is accommodate for any human error or blade wiggle, because the two pieces will have the same “imperfections” at the same place. The imperfections are complimentary, so they fit together just as perfectly.
I have yet to master it, but it DOES make much more precisely fitting cuts.
35120 posts in 4394 days
#7 posted 08-14-2011 04:14 PM
Dennis did something like that on stack cutting on the music box he posted.
TopamaxSurvivor
18266 posts in 3670 days
#8 posted 08-14-2011 08:23 PM
Debbie, Yoiu stole me thunder ;-)) Guess I am now tipless ;-((
#9 posted 08-14-2011 11:23 PM
oops :) Sorry T.S.
View WayneC's profile
WayneC
13754 posts in 4091 days
#10 posted 08-14-2011 11:29 PM
Shooting boards can be used to trim the wood after cuts, making angles exact…..
View Joe Lyddon's profile
Joe Lyddon
10091 posts in 4046 days
#11 posted 08-15-2011 12:00 AM
bentlyj,
COOL TIP!
View glue4you's profile
glue4you
162 posts in 2474 days
#12 posted 08-15-2011 12:17 AM
Strange thing I find is: The older the machines the better the results. Bought a DW320 radial arm saw recently. Set it up once, works fine. If I do the same with my 2001 table saw I can adjust, double check, measure twice and cut once. But once I cut, it’s out of square. I still hope it’s not me.
I do what bentlyj suggests: I make test cuts on scrap.
In addition, I find these Japanese razor saws with the fixed angle guides (the ones with the magnets that you clamp on) really helpful. Have one for cutting dovetails and will soon buy one for perfect 90 and 45 degree cuts. I like the fact that you don’t have to check anything apart from one straight edge on your stock, but you need that anyway. If you use a saw with inline teeth there’s no way you could possibly screw up that cut. Problem with that technique is, that you can’t easily batch out multiples as with a ts and stop blocks. If you need consistent lenghts you have to find a way to achieve that.
-- Alex ----- Bavaria in Germany
Joe Lyddon
#13 posted 08-15-2011 12:39 AM
glue4you:
”with the fixed angle guides”
Could you please post a link to some of those?
Sounds good…
Thank you.
23914 posts in 3845 days
#14 posted 08-15-2011 12:39 AM
If you don’t have a mitre saw there is a very simple way to get the perfect cut.
1. Mark your mitres and cut with a hand saw.
2. put your two cut pieces together
3. If there are any gaps run a thin blade like a hacksaw or pull saw through the joint.
4. Keep repeating the process until you have a perfect joint.
View Jim Finn's profile
Jim Finn
2656 posts in 2916 days
#15 posted 08-15-2011 03:08 PM
msdebbie; .................. I cut two pieces of wood at a time a lot. This is how I do inlays. Just tilt the table 3.7 degrees and after cutting the top piece drops into the bottom one perfectly. (This is called Double Bevel Inlay) With the table level I have done intarsia by stack cutting different types of wood for a perfect fit. Easy to do. Both intarsia and inlay came out perfect the first try.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
showing 1 through 15 of 30 replies
