how much room do i leave
Forum topic by rogerw posted 08-13-2011 09:30 PM 724 views 0 times favorited 3 replies Add to Favorites Watch
View rogerw's profile
rogerw
262 posts in 2565 days
08-13-2011 09:30 PM
i have a router table top that is approx 24×32 and will be after trimming the edges 25.5×33.5. i want to leave as much in front of the router as possible for work support and still leave ample room for a fence and it’s movement behind it. for those of you that have built a “norm (nyw)” size router table, how far in from the back edge is the center of your router?
gracious!
-- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" <<
3 replies so far
View jusfine's profile
jusfine
2422 posts in 2802 days
#1 posted 08-13-2011 10:25 PM
Mine is about 15” from the back and about the same from the front.
All the Best!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View wingate_52's profile
wingate_52
224 posts in 2445 days
#2 posted 08-13-2011 10:38 PM
Mine is well off centre. I work to the front, but can go to the left. I have 2 tables. A large and a larger. My router is on a Jessem lift plate and can go from a large table with mainly a vacuum fence that gives me plenty of room for guitar routing. The larger table has the Incra jig. To tables, different purposes.
View cutmantom's profile
cutmantom
401 posts in 2911 days
#3 posted 08-13-2011 10:45 PM
if you mount it closer to the front it is easier to clamp feather boards when running narrow stock, if you need to raise a panel just work on the other side of the table
