colouring epoxy
« back to Woodturning forum
Forum topic by Karda posted 10-02-2018 06:37 AM 539 views 0 times favorited 9 replies Add to Favorites Watch
View Karda's profile
Karda
1379 posts in 788 days
10-02-2018 06:37 AM
Hi, I want something to put in my epoxy to make the cracks in my bowls stand out, be a feature instead of a defect, any ideas
9 replies so far
View Jim Finn's profile
Jim Finn
2688 posts in 3156 days
#1 posted 10-02-2018 11:36 AM
I use colored chalk. Either powdered chalk line chalk from Lowes or make my own dust from colored chalkboard chalk from Hobby Lobby or walmart. I like to use blue.
-- No PHD just a DD214 Website> craftingcouple.com
View poospleasures's profile
poospleasures
782 posts in 2718 days
#2 posted 10-02-2018 01:31 PM
You can use finely ground glitter from Hobby Lobby or Walmart. I keep many colors in stock. You can fill cracks or tool lines into project parts to add accents.
-- I,ve had amnesia for as long as I can remember. Vernon
View JayT's profile
JayT
6003 posts in 2445 days
#3 posted 10-02-2018 01:39 PM
I use Testor model paint to color epoxy and it works well. It is cheap, easy to find and available in a wide variety of colors, including metallics.
View pottz's profile
pottz
3812 posts in 1219 days
#4 posted 10-02-2018 02:01 PM
the skies the limit on what you can do,pen makers use a multitude of dyes,powders and metals.ive use ground stone like turquoise to fill cracks.metallic powders like gold and copper give a cool look also.have fun with it.
View johnstoneb's profile
johnstoneb
3070 posts in 2407 days
#5 posted 10-02-2018 02:06 PM
x1 pottz.
-- Bruce, Boise, ID
View OSU55's profile
OSU55
2022 posts in 2224 days
#6 posted 10-02-2018 04:29 PM
I use all types of things – glitter, powdered casting metals, coffee grounds, saw dust – never tried chalk, I will have to try it
View Kelly's profile
Kelly
2179 posts in 3179 days
#7 posted 10-16-2018 06:48 AM
As others point out, you can add all manner of things. I’ve used oyster shells and turquoise powder for card embossing and ended up with what passed for turquoise, once polished.
View RobHannon's profile
RobHannon
221 posts in 765 days
#8 posted 10-16-2018 01:03 PM
Avoid anything waterbased, otherwise sky is the limit. Printer toner, tattoo ink, pigments, oil paints, chalk, crushed stone or shell, glitter, sawdust, cocoa powder, spices, coolaid powder, etc.
View Lazyman's profile
Lazyman
2702 posts in 1622 days
#9 posted 10-16-2018 01:15 PM
I’ve used black Transtint dyes and it seems to work fine. Not sure if that is recommended or not but it worked. They are a little pricey but it only takes a drop or two. I have also used fine copper and brass dust but it takes a lot before you get the look of actual metal. Another option is to put a dry filler into the cracks and drip CA over it. I actually like that better than epoxy with coarse materials like turquoise sand, especially in voids like worm holes. Note: Once you put something like stone in, don’t use your turning tools.
