How to go about this one...
Forum topic by zindel posted 08-12-2011 09:57 PM 959 views 0 times favorited 8 replies Add to Favorites Watch
View zindel's profile
zindel
257 posts in 2645 days
08-12-2011 09:57 PM
Okay so first off i just got engaged and yes I am already being put to work on wedding plans…not so much fun…however i was very excited to hear that she would like some candle holders made for guests as gifts…so a very good excuse to run to the shop all i want. Anyways getting on with it…with my many piles of scrap walnut i am going to glue them up and cut it all down to about a 3×3 or 2.5×2.5 its just going to hold a single tea light. Now my question is how would everyone of you go about getting them cut down? my table saw with a my sled goes to about 3” and that might be a bit tough on my ts to cut that many with it being walnut and all and using the full blade. Suggestions?
-- If you can't fix it with a hammer, You've got an electrical problem.
8 replies so far
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3154 days
#1 posted 08-12-2011 11:32 PM
Grats on the engagement!
A little confused here…are you gluing them up and then making cubes? If so, it would be 3×3 x 3???
If so, that’d be a something better accomplished on a bandsaw.
If it is 3×3 x 1-ish, then I would rip boards to width and section off with the miter gauge on the TS.
-- jay, www.allaboutastro.com
View Don W's profile
Don W
18707 posts in 2563 days
#2 posted 08-13-2011 12:15 AM
I agree with jay, another option would be a band saw.
View Richard's profile
Richard
1916 posts in 2686 days
#3 posted 08-17-2011 10:03 PM
Oh No , you have already got a Honey Do List and your not even married yet. :) Well at least it’s a Woodworking list.
View Logan Craig's profile
Logan Craig
41 posts in 2501 days
#4 posted 08-18-2011 10:38 PM
Sounds like he’s piling all his wood together with some glue to make a single uniform(ish) board about 3×3. Then he’ll cut to whatever height is desired. A band saw would be great, but I’m guessing if he had one he wouldn’t be asking the question :)
No, if you’re trying to cut bigger than your blade height you’re pretty much stuck with making two passes on the table saw for each cut – cut, flip, cut. If your fence/jig system is nice enough its not as bad as it sounds. I want to make me a sled for this kind of thing.
The really fun part will be making the holes for the candles….Drill press and a big Forstner bit? How many guests do you have? Might have to un-invite some folks…
-- Logan
zindel
#5 posted 08-18-2011 10:48 PM
yeah i do have a band saw but it doesn’t have a fence so i may have to go about getting one of those. and yes your right i am putting multiple boards together to create a single cube 2.5” all around. Seems like the bandsaw is the way to go i was just thinking with walnut that may take quite some time.
I am expecting some 200 people but i don’t think i will make that many ha more than likely i will have only enough scrap walnut for about 100 so the rest will get something a little less fun.
I did make a prototype already and it turned out great and yes the hole drilling was quite fun :) 1 1/2” Forsner bit worked perfectly and it looks very good!
Don W
#6 posted 08-19-2011 02:26 AM
For a fence a simple L shaped piece clamped will work.
View Dallas's profile
Dallas
3599 posts in 2482 days
#7 posted 08-19-2011 03:19 AM
I agree with Don W. I use a 30” piece of bed frame rail with a piece of 3/4” birch plywood bolted to it as a band saw fence. It’s been working well for the last year or so.
Don W
#8 posted 08-19-2011 05:18 AM
I made a fence for my bandsaw, but before I made it, its all I used.
