Flat Top Grind 10" Saw Blade
Forum topic by rlrjr posted 08-11-2011 08:09 PM 6926 views 0 times favorited 8 replies Add to Favorites Watch
View rlrjr's profile
65 posts in 2773 days
08-11-2011 08:09 PM
Does anyone know where you can buy one of these things? I’ve been to every big box store, Harbor Freight and all over the web and I cannot find one…....I need one to put keys on mitered corners….all the blades I can find have alternate tops which leaves a small triangle at the bottom of the groove when you cut it on the saw.
-- When I works, I works hard. When I sits, I sits loose. And when I thinks I falls asleep.--
8 replies so far
View gizmodyne's profile
1771 posts in 4024 days
#1 posted 08-11-2011 08:29 PM
Freud makes a straight line rip blade. That is what I bought for the same purpose (miter keys).
-- -John "Do I have to keep typing a smiley? Just assume it's a joke."
View David Kirtley's profile
David Kirtley
1286 posts in 2932 days
#2 posted 08-11-2011 10:40 PM
You could also use one blade from a stack dado set.
-- Woodworking shouldn't cost a fortune:
View sawdustphill's profile
53 posts in 2624 days
#3 posted 08-11-2011 11:06 PM sell a blade just for the purpose of cutting flat bottom grooves I think it is an 8 in.
Phillip from Ky.
View kpo101's profile
32 posts in 2563 days
#4 posted 08-12-2011 05:02 AM
Freud LU83R or LU84M are the two blades in the Freud family that cuts a flat bottom. Take a look at this site picture and it will show you the flat cutting tooth and the other raker teeth (right and left).
-- When the problem becomes just too much, There is always the directions!! Karl O. of Louisiana
View gfadvm's profile
14940 posts in 2624 days
#5 posted 08-12-2011 05:11 AM
I use my Freud box joint blades to cut splines in mitered joints. They are not only flat top blades but cut very cleanly. Use a very thin backer board for no tear out and very clean cuts. I bought my box joint blades at HD for $95.
View WinterSun's profile
163 posts in 2544 days
#6 posted 08-12-2011 09:58 AM
kpo101—ATBR blades like that don’t actually cut a totally flat bottom. They leave a profile somewhat akin to this: |\_/| (not unlike a stack dado) because the raker doesn’t cut quite as deep as the other teeth. It’s better than a straight ATB blade for cutting slots for keys/splines, but it can’t match a true FTG blade. I use a Freud LM72 for that purpose.
-- Rory // Milwaukee, WI
4909 posts in 2427 days
#7 posted 08-12-2011 01:05 PM
Forrest will grind a WW II to that spec, I can’t remember the exact nomenclature they use for it but if you talk to them on the phone they can tell you. What has kept me from getting one is the cost, I seem to remember it was in the $130 range (10”). For splines on mitered corners I’ve been using a Freud rip blade.
View knotscott's profile
7938 posts in 3310 days
#8 posted 08-12-2011 05:19 PM
A flat top grind (FTG) is the only grind that will give a truly flat bottom. WinterSun and Rick3DDD are correct that ATB/R and TCG blades do not leave truly flat bottoms even though they have a flat raker tooth….the other teeth protrude above the raker and leaves a small groove either at the edges or in the middle.
