Finishing pine for outdoor use
Forum topic by therookie posted 08-11-2011 06:32 PM 20071 views 0 times favorited 5 replies Add to Favorites Watch
View therookie's profile
therookie
887 posts in 3065 days
08-11-2011 06:32 PM
What does everyone suggest for an outdoor pine finish thinned down linseed oil or would thompsons water sealer.
-- http://aewoodworks.webs.com
5 replies so far
View dbhost's profile
dbhost
5767 posts in 3470 days
#1 posted 08-11-2011 06:48 PM
The only way I put pine outside is pressure treated, and slathered with either Thompsons, or a LOT of primer and paint… Pine loves to rot, you need to protect it…
View Steven H's profile
Steven H
1117 posts in 3298 days
#2 posted 08-11-2011 07:26 PM
boiled linseed oil is fine, just apply often
if your going to paint use oil based primer and high quality paint.
Forget thompson water
View lew's profile
lew
12500 posts in 3993 days
#3 posted 08-11-2011 08:13 PM
Adam,
If the piece is going to be protected- like on a covered porch- probably the oil/paint will work. If it is going to be completely exposed not much is going to prevent it from rotting eventually. If you can get southern yellow pine, it will last a lot longer than white pine or spruce.
Lew
View Bill White's profile
Bill White
5148 posts in 4198 days
#4 posted 08-11-2011 11:08 PM
Ain’t gonna last for long unless it is true slow-growth heart pine.
Bill
-- bill@magraphics.us
View pjones46's profile
pjones46
1001 posts in 2881 days
#5 posted 08-14-2011 06:41 AM
I have made garden benches from old growth local New England pine from a mill down the street from me. Coated them with Cabots Australian oil four years ago and left them out to the weather since. There has been “NO” sign of rot yet. I dipped the ends of the pine which touched the ground in a coffee can of the oil allowing the end gain to soak up as much as it could, and on the rest did as the can instructions rcommended. This year I gave them another coat just to freshen up the color.
As I said, these are outside 24/7, 365 days for four years and they look just as good as they did when I built them, however, the pine you buy at a lumber yard is junk because it is about the 9th generation and not old growth. Try to find a mill near you that is cutting old growth trees and allow it to air dry for about 6 to eight months, it will outlast you.
-- Respectfully, Paul
