| Forum topic by norman | posted 108 days ago | 727 views | 0 times favorited | 13 replies | ![]() |
108 days ago |
Topic tags/keywords: mdf utility cabinets |
108 days ago |
Give them a good coat of paint and they should be alright. I would just worry about where the hinges attach. MDF doesn’t hold screws well. -- Gary, East TX -- The longest journey begins with a single step. |
108 days ago |
mdf is fine when it is dry.. paint all surfaces. Also, gary is right about hinges. be careful -- making sawdust.... |
108 days ago |
A trick my father-in-law taught me. Layout where your screws go then bore them out with a 1/4” bit and make the holes a bit deep than the screws you are using then glue in a dowel and let dry. Trim and sand flush and you now have wood to screw into. The other thing is that MDF is very thirsty and a lot of paint will get soaked up. You can use glue sizing after you have completed sanding. You can make glue sizing by using standard carpenters glue and mixing in water about 2 parts glue and 1 part water, it should very fluid (and a little goes a go distance) and be brushed on and let dry. A lite sanding should be done once dry, two coats should do. Hope this helps. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
108 days ago |
Should be OK. Pre-drill all your holes. -- Dave Herron, Boise, ID -- How hard can it be? It's only wood! |
107 days ago |
Sorry I missed the point that these were prefabbed. They should work fine, and just be heavy. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
107 days ago |
I’d just buy the sheets of MDF and build my own. I know those will hold up! |
107 days ago |
What I did with my MDF cabinets…...I built treated 2×4 bases that the MDF cabinets set on. That way any moisture, or any thing else doesn’t get into the MDF. Plus I sprayed mine with poly before painting. Plus they are a little higher up so I don’t have to bend over quite as far to work off of. Damn my eyesight is getting bad! |
106 days ago |
Couple of comments on MDF -I live in Chicago and have kept MDF panels in my garage, unpainted, waiting for projects, for 2-3yrs. No problems. -- Gerry |
106 days ago |
If I’m not mistaken, I think I’ve seen screws for sale made specifically for MDF. They have a wide thread pattern and require predrilling with the appropriately-sized drill. I’ll try to see if I can figure out where I saw them and post the location. I’m thinking McFeeley’s. -- Earle Wright, Lenoir City, Tennessee |
106 days ago |
Found it. It was McFeeley’s. There’s a whole page of fasteners and inserts on the following link for products to be used with MDF. http://www.mcfeelys.com/search/MDF Hope this helps! -- Earle Wright, Lenoir City, Tennessee |
106 days ago |
Oops! I also missed the point that these were prefabbed cabinets. And, here I thought I’d found a really neat solution to your problem ! Oh, well, if you want to build some more yourself, that link I just posted should help. -- Earle Wright, Lenoir City, Tennessee |
106 days ago |
I had 2 of the large cabinets you are talking about. They served me well until I got about a foot or so of water during Katrina. They are useless once soaked, but otherwise they were fine. -- Charlie M. "Woodworking - patience = firewood" |
106 days ago |
i built my kitchen cabinet doors out of mdf. you can see my pics under my projects. i’ve never had a problem with screws coming out. i used 35 millimeter cupped hinges. And they are painted. -- Joey, Magee, Ms http://woodnwaresms.com |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1045 |
1392 |
99 |
254 |
90 |
Woodworking Trade & Swap
181 |
Coffee Lounge
722 |
LumberJocks.com Site Feedback
240 |
