08-10-2011 10:02 PM
Been a while since I’ve been on here. Been a busy summer so far. working a lot, getting some bike riding in here and there, visiting the kids, etc., everything but making sawdust. In fact I haven’t been out there since completing the dollhouse 3 months ago.
My current project is finally getting around to building a new router table. The first one I built has served me well but has sagged in the middle of the table from the weight of the router. Can’t complain though as it is probably close to ten years old if not older. I don’t remember exactly when I built it. Its a small, bench-top style. This one is going to be floor model I think. I doubt if it will be even close to the fancy ones I see on here but if I’m happy with it then that’s all that matters, right?
ok… enough rambling… on with the question… well at least leading up to it. My wife and I were at one of those places where you can get second hand cabinets, doors, and other construction products at a cheap price. A 3’x4’ piece of double-sided laminated particle board caught my eye and they only wanted a couple bucks for it. so I bought it. I cut the one to finish size and the other one close to that with the intent of using a flush trim bit to match them up.
now… the question… yes… here at last… what kind of adhesive can I use that will bond to laminate to glue these pieces together? I realize I will have to scuff up the laminate before applying the adhesive I just don’t know the best choice.
Any ideas???
Thanx people :)
Roger
-- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" <<
12 replies so far
#1 posted 08-10-2011 10:15 PM
I would use contact or expoxy
#2 posted 08-10-2011 10:24 PM
You want to sandwich layers of laminate?
Scuff heavily and use liquid nails or epoxy or contact cement, and clamp heavily.
If what you mean by laminate is melamine board, you can try melamine glue.
#3 posted 08-10-2011 10:28 PM
it’s white and is what cabinets are typically surfaced with.
#4 posted 08-11-2011 12:32 AM
I would recommend contact cement. Epoxy would be a pain if used on a large surface area!!! AND liquid nails would be hard to get completely flat without some creative clamping!!!!
Still use sandpaper to scuff the surface first.
-- I have metal in my neck but wood in my blood!!
#5 posted 08-11-2011 04:21 AM
Weldwood Gel Contact Cement is MUCH more user friendly than the conventional liquid contact cement which I refer to as “elephant snot”.
#6 posted 08-11-2011 05:18 AM
It sounds like you’re gluing melamine. It’s hard to scuff it well enough to get most glues to stick.
I don’t know how well melamine glue works for laminating, but it might be worth getting a bottle and testing it.
I would probably do something like tilt my table saw to 45 degrees and make real shallow scoring cuts shooting for 3/64” deep going both ways in each piece, then scuff and glue. Since you’re sandwiching two layers for structural reasons, the cuts won’t be a problem. In veneering over melamine, you can’t get away with those scoring cuts because they’ll show through the veneer.
Read this thread at Woodweb:
http://www.woodweb.com/knowledge_base/Bonding_Laminate_to_Melamine.html
#7 posted 08-11-2011 12:00 PM
Why use glue at all? I’m assuming this is planned as the top surface of your router table. So one side (the top) you WANT the melamine, but the underside does not matter. Right? If that’s the case I might just screw the two pieces together with a few dozen well-placed screws from the bottom. Just be careful they don’t come through the top! I’d probably drill small pilot holes and countersink them too. If the material is 3/4 inch, you have 1 1/2 total, so a 1 inch screw countersunk should be safe.
-- Some problems are best solved with an optimistic approach. Optimism shines a light on alternatives that are otherwise not visible.
#8 posted 08-11-2011 05:05 PM
i never considered screws. definately simplifies the whole situation! thanx for the different approach. i like it.
these are the two boards i want to double up. not sure if it’s laminate or melamine.
roger
#9 posted 08-11-2011 11:12 PM
I would use contact cement
Phillip from Ky.
#10 posted 08-13-2011 01:31 PM
i think i have chosen the screw method… strategically placed that is. just have to figure out where i DON’T want screws.
thanx
#11 posted 08-13-2011 01:57 PM
put a screw at each corner, then make your top, when finished put the rest of the screws in, also in the bottom layer you could cut the hole for the router a little smaller than the top layer to provide a ledge to support the router plate, screw driven in this lip would provide leveling adjustment for the plate
#12 posted 08-13-2011 05:24 PM
sounds like a plan cutmantom. don’t need to figure it out your way.
that’s what i like about this place…. so many ideas, so little time! lol
thanx!
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12033 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2108 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
431 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
340 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1370 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
4907 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
6696 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
28069 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
212 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5413 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1420 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6233 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1388 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2154 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1187 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
4759 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2201 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
8847 |
