Ceramic Sharpening Stone Care and Use
« back to Hand Tools forum
Forum topic by wingate_52 posted 08-10-2011 07:26 PM 3011 views 0 times favorited 3 replies Add to Favorites Watch
View wingate_52's profile
wingate_52
224 posts in 2596 days
08-10-2011 07:26 PM
Topic tags/keywords: sharpening
I have been recomended to use the stone dry and to clean, by washing with soapy water. Any tips for use and maintainance?
3 replies so far
View Toolz's profile
Toolz
1004 posts in 3769 days
#1 posted 08-10-2011 07:59 PM
I keep a couple in my carving toolbox and lubricate them with clear tap water when using instead of using dry. Other than that I only scrub them with soapy water and a surgical scrub brush when they turn black with metal particles. That is all I have ever done and it works satisfactory for me.
-- Larry "Work like a Captain but Play like a Pirate!"
View santawitler's profile
santawitler
1 post in 2504 days
#2 posted 08-14-2011 05:09 AM
I have two in my carving kit, I have used them both dry and with water. If they get real dirty, I use detergent and boil them for a bit to open the pores on the stones..
Hope that helps.
View BigJimAK's profile
BigJimAK
30 posts in 3317 days
#3 posted 08-17-2011 05:50 AM
Wingate,
No matter the brand, whether ceramic or water stone, you should flatten them regularly… as in before each use, to ensure you’re getting a flat finish on your tool. Actually, if doing prolonged sharpening such as flattening a plane back, you may need several flattenings to get a really good surface.
You’ll see demonstrations of this if you check out DVDs from folks like David Charlesworth or Rob Cosman, or on Rob’s “Online Hand Took Workshop” site. http://robcosman.memberlodge.com/
-- Jim in Alaska
