Homemade drum sander(new idea)
Forum topic by higtron posted 08-10-2011 06:36 PM 15895 views 24 times favorited 27 replies Add to Favorites Watch
View higtron's profile
higtron
247 posts in 2919 days
08-10-2011 06:36 PM
So I was originally thinking of building a drum sander got a free plan off of woodgears, but the motor seems to be my only problem with this idea. And this plan just keeps knawing away in my head(not that theres much to knaw on)so last night I’m in the shop and have this aha moment. I have a Gizzly lathe G0462 2horse variable speed motor 40” bed, 8” from bed to center of spur drive my big idea(and not original as it turns out) is mount the drum between centers, and build a removeable, adjustable table that afixes to the bed. My question is could this cause exessive wear, and possibly burn out the motor on my lathe? Because from my perspective thats the only downside. So let me have it go ahead squash my dream, rain on my parade etc…...
-- A friend will help you move, a good friend will help you move a body
27 replies so far
higtron
#1 posted 08-10-2011 06:50 PM
Some one on another foum suggested that a LJ has Built a simalar contraption I would love to pick this persons brain. Who is this LJ ?
View JoshJock's profile
JoshJock
94 posts in 3084 days
#2 posted 08-10-2011 07:22 PM
Higtron: I actually use an old craftsman lathe with a 1hp motor and it works wonderful. I’ll post some pics later. You have the right idea, I made my table with plywood and I glued a sand paper to another plywood piece in order to true the drum (that is if you are making the drum out of wood as well). In order not to force the motor, I make several passes and each pass I am able to sand up to 1/16 ( of course also depending on the grade of sanding paper you use) I use a 80 grid and it works for me. I’ve even used it to make my own veneer for a guitar that i’m working on. this is the guide i used to base myself when building mine http://www.woodturningonline.com/assets/turning_articles/lathe_mounted_drum_sander/lathe_mounted_drum_sander.html
I hope this helps!
-- "Does this lathe makes my butt look big?"
View SASmith               's profile
SASmith
1850 posts in 3229 days
#3 posted 08-11-2011 01:26 AM
Here is a concept from shipwright:
http://lumberjocks.com/topics/25559
Here is another link:
http://www.shopsmith.com/academy/drumsand/
toward the bottom is what you are describing
This is a v-drum style sander. This is a commercial model but easy to build yourself.
http://www.shopsmithacademy.com/Tips_Archives/SST106_Sand_Flee.htm
I think a v-drum sander would be much easier to make than a thickness sander.
Good luck
-- Scott Smith, Southern Illinois
higtron
#4 posted 08-11-2011 07:53 PM
Well I’ve made up my mind to proceed with this build, I will be advanceing the material through the drum sander manually for now if I get alot of burning I will rethink that at a later date. Now my idea for the drum is cut 5” circles and glue the discs together to form a 18” drum I’m wanting a hook and loop system my question is what is the best glue to use for this application, and say I use contact cement it seems like i would only get one take at being perfect, because any bubbles or voids would telegraph through to to the material being sanded. Also I already have lots of 3/4 ply scraps would this make for a stable drum, the reson I ask is most everyone who has built one and put it on the net uses MDF it seems to me plywood would also be stable, and as an added bonus moisture wouldn’t make it plump just wondering is it just the lesser price of MDF that makes it attractive for this app, or is MDF more stable.
SASmith
#5 posted 08-12-2011 01:09 AM
I think the plywood will work well.
Here is a thread on drum construction.
http://lumberjocks.com/topics/28260
higtron
#6 posted 08-12-2011 03:45 AM
Well as it turns out I decided to go with the ply for the discs, drilled a 1/4” hole in each plywood square centered, drilled a 1/4” hole from the edge of my cross cut sled half the diamiter of my finished disc which is 2 3/4” turned a 14” dowel on my lathe and cut all my discs on the table saw it worked slick. I think I’m going to glue them up in batches since there are 19 of them tomorrow I’ll get me a length of 1/4” all thread for alighnment purposes. This is starting to get interesting.
higtron
#7 posted 08-15-2011 09:26 AM
well I was able to get my glue up the drum unit for my lathe powered thickness sander.
the pivot point is a 1/4” dowel on my crosscut sled it worked slick for cutting the discs, and finally the finished drum unit the big end is wher i’ll mount my face plate I used a 1/4” steel rod through the middle of all the discs fo alighnment purposes.
View Jonathan Alson's profile
Jonathan Alson
18 posts in 2724 days
#8 posted 08-15-2011 11:31 AM
Looking good, interested to see how this turns out. Keep us updated
drum sander reviews
higtron
#9 posted 08-23-2011 08:26 PM
I’ve been working on my thickness sander again I’ve made a sturdy base for the ajustable table it’s easy as 6 wing nuts to mount onto the lathe.
higtron
#10 posted 08-28-2011 09:53 PM
alright I’ve finished my lathe powered thickness sander and I have a few photos and a video of it in opperation. the adjustable table is made of MDF 1 1/2” thick attached to the removable table with a piano hinge there is a hieghth adjusment bolt that lifts the table. The drum is hook and loop sand paper and the velcro mat and sand paper was my biggest investment. I trued the drum by glueing 4” belt sanding-belt to a 3/4” piece of particle board, on one end I had 50 grit and the other 80 grit it worked great. The dust collection is better than I hoped for, I can’t see any airbourn dust escapeing at all.
Here is the link for the video of the sander in action http://www.youtube.com/watch?v=kGVBo1aruZQ
View Dark_Lightning's profile
Dark_Lightning
3367 posts in 3351 days
#11 posted 08-29-2011 03:35 AM
Excellent! This saves me from buying yet another machine to clog my extremely limited work space. I can use one rail of my Record Lathe as the pivot arm. This will be really simple! Thanks for the efforts.
-- Random Orbital Nailer
View Jim Jakosh's profile
Jim Jakosh
21977 posts in 3347 days
#12 posted 08-29-2011 05:05 AM
That is really nice and it works good too in the video. What grit paper do you use and what RPM is it running at?
I really like the dust collector because a sanding machine creates so much fine dust that get all over the place.
Now you have just placed another project in the job jar!!
Thanks for sharing!!!.............Jim
View DamnYankee's profile
DamnYankee
3312 posts in 2804 days
#13 posted 08-29-2011 06:11 AM
Sweet idea
-- Shameless - Winner of two Stumpy Nubs Awards
higtron
#14 posted 08-29-2011 12:10 PM
Thanks guys, Jim I’m useing 80 grit at 1700 rpm.
View pariswoodworking's profile
pariswoodworking
389 posts in 2727 days
#15 posted 08-29-2011 10:01 PM
It turned out great. I may have to buy a lathe so I can build one.:)
-- Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. -- Albert Einstein
