| Forum topic by Tim Kindrick | posted 678 days ago | 1990 views | 0 times favorited | 20 replies | ![]() |
678 days ago |
Topic tags/keywords: question trick tip resource spray gun finishing refurbishing sanding Now that I have your attention… What is the best technique or method to “Rubbing Out” a finish? I’m not that interested in french polishing per se’....... just want to get the best out of each project. Also what is the best method of getting into the inside corners when rubbing out the finish? Btw, this is a serious question!!! Thanks!!! LOL -- I have metal in my neck but wood in my blood!! |
20 replies so far
#1 posted 678 days ago |
I’ve used pumice and rottenstone, with paraffin oil as a lubricant. You do the pumice first because it’s coarser, then the rottenstone, using a soft cloth or a felt eraser in small, circular motions. Very labor intensive, very messy, but great results. I’ve also done the same routing with automotive polish followed by carnuba wax. The results are pretty much the same, not as messy, and, as a bonus, it smells good. :-) -- Charlie M. "Woodworking - patience = firewood" |
#2 posted 678 days ago |
Thanks Charlie!!! As I’ve mentioned in other forum posts, I’ve used Turtle Wax Car Polish but it gets into cracks and wood grain and leaves little white specks everywhere!!!! I usually apply furniture wax and mineral spirits (50/50) with 0000 steel wool but sometimes I need/want a more “high gloss” finish….... I have heard of pumice and rottenstone before but I have no idea where to get these… any suggestions? -- I have metal in my neck but wood in my blood!! |
#3 posted 678 days ago |
An old electric tooth brush is very good for tight corners -- Pete G: If you always do what you always did you'll always get what you always got |
#4 posted 677 days ago |
I used to. -- Getting old is a good thing, but being old kinda stinks. |
#5 posted 677 days ago |
Now Tim, that’s just a little TOO personal. -- Harold |
#6 posted 677 days ago |
Both of these places carry pumice and rottenstone. -- Tim-- http://www.tmuli.com |
#7 posted 677 days ago |
And here I was trying to take the high road for once. :-) -- Charlie M. "Woodworking - patience = firewood" |
#8 posted 677 days ago |
Damn, my bad!!!!! I just thought I would add a little humor to the question just for fun…... Should have known better. Thanks for trying Charlie and thanks for the links Tim and the tip Pete. If anyone has any real tips, tricks or suggestions about rubbing out finishes…. please post them. I have read several other threads where people had questions like “What is rubbing out finishes all about” so I was actually hoping to collect different opinions on this subject here. -- I have metal in my neck but wood in my blood!! |
#9 posted 677 days ago |
Great post topic – love this new forum! On that note… Can someone clarify if these techniques are suitable for water-based poly-crylic finishes or just poly-urethane and laquer. Second clarification – how long do you let the clear finish cure before rubbing? -- Jim, North Vancouver, BC |
#10 posted 677 days ago |
scrabby: Yes, you can rub out a water-based finish. In my experience, 48 hours drying time is plenty, although I’ve heard recommendations of a week or more. -- Charlie M. "Woodworking - patience = firewood" |
#11 posted 677 days ago |
Thanks Charlie – I’m going to give it a shot on a desk top I’m currrently finishing. Even when I apply water-base poly in thin layers with shop towels (which I also learned folllowing this forum), I’m not totally satisfied with the final smoothness, so I look forward to this next stage of my finishing learning curve. Cheers. -- Jim, North Vancouver, BC |
#12 posted 677 days ago |
When I first got back into woodworking I dreaded the finish work I’m kinda lazy so I could never get a good finish without a lot of effort. So I started reading about finishes and of course read about french polish and thought well thats way too much work for a lazy guy like myself, but maybe I can adapt it. I did and I’ve been doing this finish for years now with great results and minimal work. (You know me being lazy hee hee) So the basics are 2-3 coats 1lb cut white shelac, then 2-3 coats rub on poly The 1lb cut shelac I just use a brusht to apply the shelac. Since its so thin dry time between these first couple coats is very fast. I just use regular old 220 sanding blocks between coats, don’t even need to wipe the dust off. As in a french polish the dust from each sanding works its way into the groves and since its just hardened finish, it helps build up the layers. Then I use a chunk of old t-shirt to apply the wipe on poly, also sanding in between coats. In a french polish i’ve read about the making and using of the rubbing pad and I’m sure if one wasn’t as lazy as me that would make the finish that much more awesome but well you know the t-shirt works and when I’m done I toss it in my dirty rags container and take it the the waste site at our local dump. When I first started doing this, the wipe-on poly didn’t exist, I just used a cut version of the brush on poly so if you can’t find the wipe on stuff in your town this works also. Anyway thats my 2cents worth hope it helps in some way. -- Wood and Glass they kick (well you know) Have a great day - Dug |
#13 posted 677 days ago |
Scrabby – Last year I built a breakfast bar out of hard maple. I wanted to keep the natural colour of the maple, so I used Ronseal Diamond hard acrylic water-based varnish which looks white in the can. I applied two coats straight from the can without any sanding. It was touch dry in 15 minutes and you could recoat after 2 hours. You have to work quite quickly and it doesn’t flow out like an oil-based varnish so you can’t keep going over it with your brush or you just get more brush marks. After the third coat had been on for 2 hours, I rubbed out the brush marks slowly using light pressure by hand, with P800 wet & dry paper used dry. This got rid of all the brush marks, leaving a really smooth surface. Then I wiped all the dust off with a slightly damp cloth, let it dry and applied a fourth coat. I rubbed that coat out again with P800 followed by P1200 if I remember correctly (again used dry). The resulting finish was silky smooth and very tactile. I have also used pumice and rottenstone as Charlie described on an oil-based finish which if done correctly gives you a finish like you find on a Steinway piano. As Charlie said, it is a lot of work and quite messy. I have also rubbed out Liberon Finishing Oil with a felt block and Behlen’s wool lube (which is basically expensive washing up liquid) and that removes all of the dust nibs leaving the finish smooth to the touch. Some people in the US use the brown paper bags that their groceries come in to rub out the finish and remove the dust nibs. The important thing in my opinion is that when you intend to use a new finishing regime, always take the time to work through the entire process on a test piece, before trying it on your actual project. If you mess up the test piece, figure out what you did wrong and try it on another test piece. It is worth getting it right. There are as many finishing techniques as there are woodworkers in my experience and you have to find what product/process works best for you. One thing that is universally true though, is that you can’t rush a good finish. It takes as long as it takes so don’t rush it. -- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it. |
#14 posted 677 days ago |
Great advice and feedback….thanks Brit! I’m committed to water-based products, as I work in the basement, and don’t want to expose my family to evaporating solvent in the house, so I’m going to experiment, like you suggest, to develop a regime and results I’m proud of. It would also probably help me to move away from Minwax poly to professional-grade water-base finishes like General Finishes and such. -- Jim, North Vancouver, BC |
#15 posted 677 days ago |
Thanks Guys! That’s what I was expecting from this great LJ community!!!!! Mcoyfrog, I am also too lazy for french polishing!! Even your version seems too complicated for me but thanks for the input, I’m sure someone will try it!!!!!!!! Brit Andy, I’ve read about the use of brown paper bags an d tried it a couple of times…. it didn’t work for me. I rubbbed until my arms ached but couldn’t tell much difference(except sore arms)! Btw, I just recieved the latest Grizzly catalog today and noticed they carry Behlen: Pumice and Rottenstone plus an additional Rubbing Compound…. ALL NEW PRODUCTS!!!! -- I have metal in my neck but wood in my blood!! |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
