Burn In Choices Oven or Chorded Knife Preferred?
Forum topic by Freddy3 posted 09-25-2018 12:03 PM 300 views 0 times favorited 3 replies Add to Favorites Watch
View Freddy3's profile
Freddy3
6 posts in 81 days
09-25-2018 12:03 PM
Topic tags/keywords: burn in repairs
I’m wanting to enter the personal use only furniture repair arena as a complement to my hobbyist woodworking. I’m unsure which burn in heat up method is best for me. I like the idea of being non- tethered by chords but would consider any arguments in support of this chorded method over electric ovens. Please weigh in on this LJ’s.
-- Fred
3 replies so far
View Rich's profile
Rich
3880 posts in 790 days
#1 posted 09-25-2018 04:25 PM
I have a corded knife and a butane one as well. I started with the butane knife, a M900-3210 and later picked up a corded one from Woodcraft on a whim. The pair work well together. The corded knife can sit heated and ready for use without wasting butane, and I like the butane knife because the heat is adjustable and it’s light and easy to maneuver. I generally use the corded knife for filling and the butane for leveling. Also, I recently added a battery powered soldering iron. It’s great because it heats up instantly and is perfect for applying fill to small spots.
The knives that are used with an oven are very versatile. However, you can buy curved blades for the 3210 and extra straight blades to grind into whatever shape you need. I haven’t felt the need for an oven yet in my work.
Keep in mind that there is more to repair work than hard fill alone. I use Mohawk products and have a collection of each of their fill products. The PlaneStick and E-Z Flow are probably the most challenging, but produce the best repairs. You’ll want to do hours of practice on test boards before you try a real repair. The hard fill sticks are a good compromise between a durable repair and ease of application. All you have to do is melt in the fill and scrape it flush with the leveling tool. All of these products are suitable for situations where they will see wear, like on a table top. It’s mostly a matter of selecting the product with a sheen that best fits your needs.
For any repair on a surface that won’t see wear, the softer fills are easy to work with. The Quick Fill sticks are a particular favorite. For those you need a flameless heat source. A heat gun will do, but it tends to be harder to control. I picked up the flameless heat gun (the same model from the Mohawk sites is available on Amazon for a fraction of the price) and it works very well.
I could go on, but that should give you an idea.
Here are a couple of shots of some of what I use. I usually use epoxy putty for patching, but the Timbermate (red lids in the second photo) is excellent for certain situations too. I did a blog post describing some of it a while back.
Freddy3
6 posts in 81 days
#2 posted 09-25-2018 05:17 PM
Many thanks Rich. You have given me several avenues to further look into. I hadn’t even considered butane knives. Most appreciated!
-- Fred
View Rich's profile
Rich
#3 posted 09-26-2018 12:19 AM
Glad it was helpful, Fred. BTW, I included a link when I mentioned the butane knife, but magicwoodrepair.com is a full-line Mohawk and Behlen dealer. Their prices are competitive and shipping is reasonable. They also have a rewards program that has saved me maybe 10% on purchases. Just keep shopping there and every so often it’ll pop up with a reward that you can use on your purchase.
Welcome to LJ.
