Delta 36-725 Extension Cord
Forum topic by LeopoldWallace posted 09-25-2018 02:47 AM 304 views 0 times favorited 18 replies Add to Favorites Watch
View LeopoldWallace's profile
LeopoldWallace
23 posts in 102 days
09-25-2018 02:47 AM
Purchased the aforementioned table saw a few weeks back and I’m wondering what is the correct length of extension cord to use for it?
18 replies so far
View Rick S...'s profile
Rick S...
10913 posts in 3232 days
#1 posted 09-25-2018 02:48 AM
(Deleted)
-- I Chose "The Road Less Travelled" Now I'm Totally Lost! (Ontario, CANADA)
View lumbering_on's profile
lumbering_on
574 posts in 690 days
#2 posted 09-25-2018 03:04 AM
You need to be more specific on what you are asking. You don’t even need an extension cord for it, so the question seems rather strange.
View Ripper70's profile
Ripper70
1163 posts in 1108 days
#3 posted 09-25-2018 03:16 AM
Are you running it at 110v or 220v
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
LeopoldWallace
#4 posted 09-25-2018 03:24 AM
LeopoldWallace
#5 posted 09-25-2018 03:32 AM
I work out of my carport. Closest outlet is in my laundry room about 20-25 feet from the table saw. That outlet accepts the standard three cord as found on the machine.
View EdDantes's profile
EdDantes
42 posts in 110 days
#6 posted 09-25-2018 03:33 AM
There is a chart in the manual. For 15A @ 110V: 14 AWG up to 25’, 12 AWG for 25’-50’. No cords over 50’. But realistically you are better off using 12 AWG (or even 10 AWG) regardless of length.
You should keep the run as short as possible, which often means making your own extension cord with SJOOW cord cut to length. In other words, don’t use a 25ft cord when all you need is 10ft.
All that being said, you should be running the saw on a dedicated breaker. So if you don’t have that, you should be thinking about installing a new breaker and wiring an outlet as close to the saw as possible.
LeopoldWallace
#7 posted 09-25-2018 03:39 AM
I believe 110v
- LeopoldWallace
There is a chart in the manual. For 15A @ 110V: 14 AWG up to 25 , 12 AWG for 25 -50 . No cords over 50 . But realistically you are better off using 12 AWG (or even 10 AWG) regardless of length.
You should keep the run as short as possible, which often means making your own extension cord with SJOOW cord cut to length. In other words, don t use a 25ft cord when all you need is 10ft.
All that being said, you should be running the saw on a dedicated breaker. So if you don t have that, you should be thinking about installing a new breaker and wiring an outlet as close to the saw as possible.
- EdDantes
Excuse my stupidity but that chart in the manual is a little confusing. So I should look for a 25 foot extension cord with an Ampere rating of 12???
View MrUnix's profile
MrUnix
7043 posts in 2399 days
#8 posted 09-25-2018 03:40 AM
- LeopoldWallace
I think you answered your own question.
LeopoldWallace
#9 posted 09-25-2018 03:43 AM
- LeopoldWallace
- MrUnix
Lol! But I’ve read where people have apparently damaged the table saw motor by using long cords and wrong amps. I’m obviously not an electrician but if I get a 25 foot cord what ampere rating and gauge should I get to avoid hurting my new toy?
View Rayne's profile
Rayne
1108 posts in 1739 days
#10 posted 09-25-2018 03:46 AM
- LeopoldWallace
- MrUnix
- LeopoldWallace
To answer your question fully, get a 25’, 12awg, 15 amp extension cord and you’ll be set. Some may say 20 amps, but it won’t matter due to the length. You’ll be fine with that.
EdDantes
#11 posted 09-25-2018 03:47 AM
- LeopoldWallace
Not 12 amps. 12 gauge. That saw is rated (I believe) to draw a Max of 13A at 110V. That means you need a cord that can handle 13A over 25 feet at 110V. By the chart, you could technically use 14 gauge. But don’t…just get 12 gauge.
Like this:
https://www.mcmaster.com/6953k19
LeopoldWallace
#12 posted 09-25-2018 03:50 AM
- LeopoldWallace
Not 12 amps. 12 gauge. That saw is rated (I believe) to draw a Max of 16A at 110V. That means you need a cord that can handle 16A over 25 feet.
Like this:
- EdDantes
Will this work?
https://www.homedepot.com/p/Husky-25-ft-12-3-Extension-Cord-in-Red-and-Black-HD-573-286/202532381
lumbering_on
#13 posted 09-25-2018 03:53 AM
I have the exact table saw and I have no issues running a 25’ cord on a 14 AWG cord, but a 12 AWG won’t hurt, it will just cost a bit more.
As for damage, that’s something that is based on stupidity. The Delta 36-725 is a low hp motor, and can easily bog down even without an extension cord. I think of it as a safety feature as the blade often stops if your piece starts to twist – something that can cause kickback on a more powerful saw. The thing is that as soon as you notice the blade slowing down you need to hit the stop button as the motor can damage itself otherwise. As an under-sized cord will reduce the hp available, it will bog down even quicker, which is likely when people start damaging the motor.
lumbering_on
#14 posted 09-25-2018 03:57 AM
- LeopoldWallace
Like this:
- EdDantes
Will this work?
- LeopoldWallace
It’s 12 AWG so it will do fine.
LeopoldWallace
#15 posted 09-25-2018 03:59 AM
I have the exact table saw and I have no issues running a 25 cord on a 14 AWG cord, but a 12 AWG won t hurt, it will just cost a bit more.
As for damage, that s something that is based on stupidity. The Delta 36-725 is a low hp motor, and can easily bog down even without an extension cord. I think of it as a safety feature as the blade often stops if your piece starts to twist – something that can cause kickback on a more powerful saw. The thing is that as soon as you notice the blade slowing down you need to hit the stop button as the motor can damage itself otherwise. As an under-sized cord will reduce the hp available, it will bog down even quicker, which is likely when people start damaging the motor.
- lumbering_on
Which cord do you have? My local store has zero matching what I’m looking for.
